Soundboard (PC) icon Soundboard (PC) — Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate. Try it →
I am unable to tightly close the part of JD
I Am Unable To Tightly Close The Part Of JD
I am unable to tightly close the part of JD that is the chest and shoulder section and thus the EZB does not connect consistently.
Is there a diagram on how the insides should sit so I can connect this tightly?
JD Humanoid by EZ-Robot
This seems to be a question about a product and not the software. So better suited for the manufacture, which is ezrobot. I found this tutorial for battery replacement which shows how to perform the opening and closing of the robot body. Here is the link: https://synthiam.com/Tutorials/Lesson/85?courseId=1
i saw the video and to be annest its not good to see how it looks when the dean connector is inplace. also i would not recoment leaving the screws in while assemble the chest.it makes it more difficult. my appolegies if i sound disrespectfull,dont mean to.
Nomad 6R, your helpful arrow and comments were great!  I was able to properly attach the piece so it sits flush!  Thank you SO MUCH!
hi smurray
was the video helpfull for you?and is the wire ok in the picture.good to hear your jd is ok. i notest when you see the video in full screen,you can see the connector in the correct place.
I didn't check the video because your reply did the trick.
ah ok .tip. its always good to see all info as you can get,aldo the problem is solved.you can still learn new things.
