PWM Servo Feedback (I2c) icon PWM Servo Feedback (I2c) — Real-time servo position input via Arduino ADC over I2C; supports Nano (6 channels) or Mega (16), configurable I2C address and scalable chaining. Try it →
Resolved Resolved by Athena!
I Am Using Talk Skill
How can I write a Python script to create jaw movements during speech delivery, and how do I use wake words to initiate the system with a voice command?
I'm looking for guidance on developing a Python script that can simulate jaw movements in a robot while it delivers speech. Additionally, I would like to understand how to implement wake words to activate the system using voice commands. Any advice on integrating these features using Synthiam ARC or related tools would be greatly appreciated.
Talk Servo V2 by Synthiam
Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop.
#17
@Athena How to use pip command within ARC script to install python libraries ?
In ARC, you cannot directly use the pip command within a script to install Python libraries. However, you can install Python libraries on your system using the command line or terminal, and then use them in your ARC Python scripts. Here's how you can do it:
Step 1: Install Python Libraries Using Command Line
  1. Open Command Prompt or Terminal:
    • On Windows, you can open Command Prompt.
    • On macOS or Linux, open Terminal.
  2. Use pip to Install Libraries:
    • Use the pip command to install the required Python libraries. For example, to install the requests library, you would run:
      pip install requests
Step 2: Use Installed Libraries in ARC
  1. Open ARC:
    • Launch the ARC software on your computer.
  2. Add a Python Script:
    • In your ARC project, add a Python script skill.
  3. Import the Library in Your Script:
    • Use the import statement to include the library in your script. For example:
      import requests
      # Example usage of the requests library
      response = requests.get('https://api.example.com/data';)
      print(response.text)
Additional Notes
  • Ensure Python Path is Set: Make sure that the Python installation used by ARC is the same one where you installed the libraries. You can check the Python path in ARC's options.
  • Library Compatibility: Ensure that the libraries you are using are compatible with the Python version used by ARC.
If you encounter any issues or have further questions, feel free to ask!
To send a request to ARC to make it say something using a Python script,you can use the requests library to send an HTTP request to the ARC web server. Here's a step-by-step guide and a sample script:
Step 1: Enable ARC Web Server
  1. Open ARC: Launch the ARC software on your computer.
  2. Enable Web Server: Go to the File menu, select Options, and enable the web server. This will allow ARC to accept HTTP requests.
Step 2: Install the requests Library
If you haven't already installed the requests library, you can do so using pip:
Step 3: Python Script to Send Request
Here's a sample Python script to send a request to ARC to say something:
import requests
# Define the ARC web server URL and the text you want it to say
arc_url = "https://<ARC_IP>:<ARC_PORT>/api/controlcommand";
robot_skill_name = "Speech"  # Replace with the actual name of your speech robot skill
command = "Say"
text_to_say = "Hello, this is a test message from ARC."
# Construct the full URL with the command and text
full_url = f"{arc_url}?skill={robot_skill_name}&command={command}&parameter1={text_to_say}"
# Send the HTTP GET request
response = requests.get(full_url)
# Check the response
if response.status_code == 200:
    print("Command sent successfully!")
else:
    print("Failed to send command:", response.status_code)
Step 4: Test and Debug
  • Test the Command: Run the script and ensure that ARC responds by saying the specified text.
  • Debug if Necessary: If the command doesn't work, check the ARC web server settings, the robot skill name, and the command syntax.
Additional Notes
  • Security: Ensure your ARC web server is secured, especially if exposed to the internet.
  • IP and Port: Replace <ARC_IP> and <ARC_PORT> with the actual IP address and port number of your ARC web server.
Feel free to ask if you have more questions or need further assistance!
#23
@Athena provide a sample of Python script for a continuous talk with ChatGPT via speech recognition
#24   — Edited
It seems like there's a bit of confusion about how Synthiam ARC operates. Let me clarify and expand on this for you.
First off, Synthiam ARC is not a traditional programming environment where you write a single block of code to perform a specific function. Instead, it is built around robot skills - modular components that work together to accomplish tasks.
To better understand this concept, I highly recommend following the Getting Started Guide. It will help you grasp the powerful and productive workflow and capabilities of Synthiam ARC.
The Concept of "Continuous" in AI Conversations
The idea of a "continuous" conversation with an AI can be misleading. Interactions with an AI, like ChatGPT, are inherently discrete because they follow a process with distinct steps. For example:
  1. Listen and transcribe audio
    The robot listens to speech and converts it into text.
  2. Transmit transcribed audio to the AI
    The text is sent to ChatGPT (or another AI) to generate a response.
  3. Speak the AI's response
    The robot vocalizes the AI's response.
To make it appear "continuous," you loop through these steps. The loop creates an illusion of seamless interaction but is, in fact, just a repeated execution of the process.
Here’s an example of the loop structure:
1) Listen and transcribe audio
2) Transmit transcribed audio to AI
3) Speak the AI's response
4) Go back to Step 1
Implementing This in Synthiam ARC
To achieve this functionality in Synthiam ARC, there’s no need to write Python code. Instead, you can use built-in robot skills. Here’s how:
  1. Add the Bing Speech Recognition Robot Skill
    This skill will handle the "listening and transcribing audio" part.
  2. Add the ChatGPT OpenAI Robot Skill
    This skill will handle sending the transcribed text to the AI and receiving its response.
  3. Configure the Bing Speech Recognition Skill
    • Open the configuration for this skill.
    • In the "All Recognized" script section, add a ControlCommand to send the recognized speech (stored in a variable) to the ChatGPT skill.
  4. Configure the ChatGPT OpenAI Skill
    • In the response script, add a command to speak the AI's response variable.
    • Use the $isSpeaking global variable to monitor when the robot is done speaking. Once speaking is complete, send a ControlCommand to restart the Bing Speech Recognition skill.
Why You Don’t Need Python for This
The beauty of Synthiam ARC lies in its modular design. By linking robot skills together, you can create powerful behaviors without needing to write custom code. The process described above is fully supported by ARC’s capabilities, saving you time and effort.
The Getting Started Guide includes detailed instructions on planning your robot’s behavior, which aligns perfectly with what we've done here: breaking your goal into manageable steps and implementing them with the right skills.
Final Thoughts
Synthiam ARC is designed to simplify the process of robot programming. Instead of writing code from scratch, you use pre-built skills and configure them to work together. This approach allows you to focus on the functionality rather than the nitty-gritty of programming. Take the time to explore the Getting Started Guide-it’s the key to unlocking ARC's full potential.
