Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Resolved Resolved by amin!
I have bought a 12v relay and i dont seem to get it working (its new)
I Have Bought A 12V Relay And I Dont Seem To Get It Working (Its New)
I am trying to connect my arduino uno to a electric lock, using a 12v relay. I have already done it with a 5v relay and it works, but with a 12v relay it is not working.
I have connected a 12v dc supply to the lock and i have cut the wire from the power supply so that it will connect to the relay COM and NO.
And connected the other side to the arduino and uploaded the code. The led light turns on indicating that the relay is working but when the signal is sent from the arduino the lock doesnt turn on.
If i connect the lock to the COM and NC then it works, but it stays on.  Are the connections ok?
USB
Servos 12
ADC 6
Digital 14
I am using the arduino software. This is the code:
#4   — Edited
Thanks a lot, i will try it. I really appreciate it that you are trying to help me:) I will try to update it first, and then I will also test the relay from the link you have provided me.
Ohh, that's great. I'll have a look at it.
Thank you!
