Screen To Camera icon Screen To Camera — Capture any screen area and stream video to a configured camera device; requires a Custom device and 100% display scaling. Try it →
Sweet! This will be a lot easier:)
For ease so you don't have to go between facebook. I was a little surprised when I saw the waves.
Datasheet
EZ-B || ITG3200 SDA - SDA SCL - SCL GND - GND 3.3V - VDD/VIO
Solder contacts together next to CLK for internal CLK
Why would you want internal CLK? Isn't the point of i2c to get the clk from the master?
For sync reasons between the devices yes however where is the clk signal coming from on the EZ-B then?
The EZ-B generates a clk on the SCL. Maybe that is why your scope capture has strageness. Maybe it's because there are conflicting clock signals?
Tonight when i get home, i'll scope an i2c communication so you can see what the SCL clock looks like.
Hopefully I get my ITG this week too
Thats what I was thinking before about the sync when I believed that it might had been reading in the ACK instead. The EZ-B clock needs be same sample speed as the ITG3200.
You get your Gyro yet? I really believe their clocks are different which prevents them from syncing.
