Hi ,
I have been doing a little reading on I2c to get familiar with what it is , as there is mention of i2c in the forum.
Is there a tutorial here on I2c ( there is reference of a BlinkM i2c , is that a tutorial for beginners?)
What I learned about I2c is .....
I2c is a chip that communicates via 2 wires system , it has memory and stores data , This data can be read and written. When communicating with an i2c you need to use address's bla bla bla ......
If a tutorial is in the works for i2c , I hope the following is included in any tutorial .....
  1. What is an I2c
  2. simple schematic with EZB and an I2c situation.....
  3. why and when to use i2c.
  4. Ez Script example
  5. a discussion on the possible applications with i2c.
Can I2c be programmed to execute an onboard script in memory for any Autonomous functions ?
Im getting in way over my head , Because I'm a newbie , I'm only putting this up because i2c is being mentioned on the forums , and i would like to get more of an idea on applications of it.
Hais.
The Learn section can be access by the top menu bar of the website. It has descriptions in the hardware section for all peripheral types. Here is a link that will help you: https://synthiam.com/Tutorials/Hardware.aspx
The link I provided will give detail of all port types - including i2c:D
will do some more reading
Hais.
