Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
I2cwrite Command For Blinkm
I hope someone can help me with this. I've been tinkering with my MinM light and Im trying to adjust the playback of the built in light script to a shorter time loop. On page 22 of the blinkM datasheet it says to send command 't', (-128 to 128). My command on EZscript would be i2cwrite (0x12,'t', -100) to shorten time. However a negative number isnt recognized as valid. Have I skipped over some important step so that this is a valid arguement?
0 would be 128, a negative number would be 128 - 100
8 bits only allows for 256 possible positions (0-255). So if the datasheet mentions a number between -128 and 128, then they mean that 0 would equal 128
-128 = 0 0 = 128 128 = 255
Ah!! Thank you DJ! I new I was missing something.
