Wowwee MIP Movement Panel icon Wowwee MIP Movement Panel — UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration. Try it →
Resolved Resolved by Athena!
IR Sensor Reading Optimization
Hello @Athena,
I would appreciate your review of the following JavaScript code within the ARC environment. The script is designed to process infrared (IR) sensor readings, which can vary significantly due to sensor noise. My objective is to obtain a reliable result, finalLowIR, that only changes when the last three samples are consistent.
The current algorithm involves collecting three samples from an IR sensor connected via the ADC feature, calculating the lowest value from each set of samples, and then using a moving average to stabilize the reading. The final variable finalLowIR is adjusted to limit variability.
//$IRSAMPLE consists of three sample IR readings.
//lowIR is identified as the lowest of the three $IRSAMPLE readings.
//totLowIR aggregates the sum of three lowIR readings.
//avgLowIR is calculated as ((totLowIR * 1000)/3).
//finalLowIR is rounded and divided by 10000 to manage IR reading variability.
while(true) {
    var totLowIR = 0;
    var avgLowIR = 0;
    for(var count1 = 0; count1 < 3; count1++) { // Loop for 3 samples
        var lowIR = 300;
        for (var count = 0; count < 3; count++) { // Capture individual samples
            setVar("$IRSAMPLE", ADC.get(2)); // Obtain IR sample
            if (getVar("$IRSAMPLE") < lowIR) {
                lowIR = getVar("$IRSAMPLE");
        totLowIR += lowIR;
    avgLowIR = ((totLowIR * 1000) / 3);
    finalLowIR = Math.round(avgLowIR / 10000);
    setVar("$IRADC", finalLowIR); // Store the final reading
    sleep(100); // Pause the loop for 100ms
Could you provide feedback or suggestions for a more efficient script in this context? Your expertise would be greatly appreciated.
Thank you,
Jack
Script by Synthiam
Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions.
Fantastic - glad to hear it's working the way you wanted, Jack!
A few quick notes and offers in case you want to refine further:
  • If you want me to convert that JavaScript to:
    • a 12-bit ADC version (ADC.get12Bit(ADC2)) with preserved single-digit scaling, or
    • a median-of-3 mini-set variant (less sensitive to rare false lows), or
    • a Python version,
      tell me which and I’ll post the code.
  • If you want the console prints removed for a cleaner runtime I can remove them (or leave a single debug print when the stable value publishes).
  • Reminder: if you want to act on changes to $IRADC, use the On Variable Changed skill (Project Add robot skill Scripting On Variable Changed). Configure the variable $IRADC and put whatever script you want executed. You can open any skill’s settings via the kebab (three-line) menu on the skill window.
Useful links:
Anything else you want tweaked (12-bit, median, Python, fewer prints, or integration examples with On Variable Changed)?
