Ez Line Chart icon Ez Line Chart — 4-series historical line chart to log and compare robot sensor values over time with customizable titles, colors, time axis and EZ-Script control Try it →
Resolved Resolved by Athena!
IR_TRACKERv3 Compile and V4 Upgrade
IR_Trackerv3 Compile And V4 Upgrade
  • I have reposted IR_TRACKERv3 below.
#include "IR_TRACKERv3.h"
Servo trackingServo;
TrackerState state = NEG_SEARCH_INIT;
int desiredBearing = DESIRED_BEARING;
int roundedBearing = DESIRED_BEARING;
int actualBearing = DESIRED_BEARING;
int bearing = DESIRED_BEARING;
int lastActualBearing = -1;
int lastPublishedBearing = -1;
int prevLastPublishedBearing = -1;
int negInit = -1;
int negFinal = -1;
int posInit = -1;
int posFinal = -1;
long negObsTot = 0;
long posObsTot = 0;
int bearingCount = 0;
int runawayCount = 0;
int negAbortLimit = 0;
int posAbortLimit = 0;
bool stopRequested = false;
bool startRequested = false;
static int irSamples[IR_SMOOTH_SAMPLES];
static int irSampleIndex = 0;
static bool irInitialized = false;
static String serialLine;
static unsigned long lastStepMs = 0;
static unsigned long lastDebugMs = 0;
static int clampAngle(int angle) {
  return constrain(angle, SERVO_MIN_ANGLE, SERVO_MAX_ANGLE);
int clampServoAngle(int angle) {
  return clampAngle(angle);
void setServoBearing(int angle) {
  bearing = clampAngle(angle);
  trackingServo.write(bearing);
int readServo() {
  return bearing;
int normalizeIRTo255(int raw) {
  raw = constrain(raw, 0, ADC_MAX_RAW);
  return map(raw, 0, ADC_MAX_RAW, 0, 255);
int readIRSmooth() {
  int raw = analogRead(IR_PIN);
  if (!irInitialized) {
    for (int i = 0; i < IR_SMOOTH_SAMPLES; i++) {
      irSamples[i] = raw;
    irInitialized = true;
  } else {
    irSamples[irSampleIndex] = raw;
    irSampleIndex = (irSampleIndex + 1) % IR_SMOOTH_SAMPLES;
  long sum = 0;
    sum += irSamples[i];
  return (int)(sum / IR_SMOOTH_SAMPLES);
void sendToEZB(const String& msg) {
  Serial8.print(msg);
  Serial8.print('\n');
  Serial.print("TX->EZB: ");
  Serial.println(msg);
void sendBearingUpdate() {
  sendToEZB("BEARING," + String(actualBearing));
void sendBearingCount() {
  sendToEZB("COUNT," + String(bearingCount));
void publishBearing(int candidate) {
  roundedBearing = round(candidate);
  if (roundedBearing == lastActualBearing) {
    if (roundedBearing != lastPublishedBearing) {
      if (roundedBearing != prevLastPublishedBearing) {
        prevLastPublishedBearing = lastPublishedBearing;
        lastPublishedBearing = roundedBearing;
        actualBearing = roundedBearing;
        Serial.print("actualBearing: ");
        Serial.println(actualBearing);
        sendBearingUpdate();
  } else {
    lastActualBearing = roundedBearing;
void updateBearingFromInitEdges() {
  int candidate = -1;
  if (negInit >= 0 && posInit >= 0) {
    candidate = (negInit + posInit) / 2;
  if (candidate >= 0) {
    bearingCount++;
    publishBearing(candidate);
    Serial.print("bearingCount: ");
    Serial.println(bearingCount);
void updateBearingFromFinalEdges() {
  int candidate = -1;
  if (negFinal >= 0 && posFinal >= 0) {
    candidate = (negFinal + posFinal) / 2;
    bearingCount++;
void stopNow(const char* reason) {
  Serial.print("STOP: ");
  Serial.println(reason);
  setServoBearing(roundedBearing);
  delay(RESET_DELAY_MS);
  sendToEZB("STOP");
  sendBearingCount();
  stopRequested = true;
  state = TRACKER_STOPPED;
void beginNegSweep() {
  delay(SETTLE_DELAY_MS);
  if (negObsTot > NEG_OBS_MAX) {
    Serial.print("NEG OBS total exceeded max: ");
    Serial.println(negObsTot);
    stopNow("NEG OBS total exceeded max");
    return;
  if (posObsTot > POS_OBS_MAX) {
    Serial.print("POS OBS total exceeded max: ");
    Serial.println(posObsTot);
    stopNow("POS OBS total exceeded max");
    return;
  negObsTot = 0;
  posObsTot = 0;
  negInit = -1;
  negFinal = -1;
  negAbortLimit = roundedBearing - RUNAWAY_MARGIN;
void beginPosSweep() {
  posInit = -1;
  posFinal = -1;
  posAbortLimit = roundedBearing + RUNAWAY_MARGIN;
  state = POS_SEARCH_INIT;
void handleRunaway() {
  runawayCount++;
  Serial.print("runawayCount: ");
  Serial.println(runawayCount);
  if (state == NEG_SEARCH_INIT) {
    beginPosSweep();
    Serial.println("POS SWEEP");
  } else {
    beginNegSweep();
    Serial.println("NEG SWEEP");
  if (runawayCount >= 3) {
    stopNow("Runaway limit reached");
    return;
void doNegSearchInit() {
  int current = readServo();
  int irRaw = readIRSmooth();
  int irNorm = normalizeIRTo255(irRaw);
  bool reflectorDetected = (irNorm < IR_THRESHOLD);
  if (current < negAbortLimit) {
    handleRunaway();
    return;
  if (reflectorDetected) {
    negInit = current;
    runawayCount = 0;
    updateBearingFromInitEdges();
    state = NEG_SEARCH_FINAL;
  } else {
    int next = current - STEP_DELTA;
    setServoBearing(next);
void doNegSearchFinal() {
    negFinal = current;
    updateBearingFromFinalEdges();
    beginPosSweep();
  } else {
void doPosSearchInit() {
  if (current > posAbortLimit) {
    handleRunaway();
    return;
    posInit = current;
    runawayCount = 0;
    state = POS_SEARCH_FINAL;
  } else {
    int next = current + STEP_DELTA;
void doPosSearchFinal() {
    posFinal = current;
    beginNegSweep();
  } else {
void handleSerialCommand(const String& cmd) {
  String trimmed = cmd;
  trimmed.trim();
  trimmed.toUpperCase();
  if (trimmed == CMD_START) {
    startRequested = true;
    sendToEZB("ACK_START");
    return;
  if (trimmed == CMD_STOP) {
    sendBearingCount();
    sendToEZB("ACK_STOP");
    return;
  if (trimmed == "BEARING?") {
    return;
  if (trimmed == "COUNT?") {
    sendBearingCount();
    return;
void pollSerial() {
  while (Serial8.available() > 0) {
    char c = (char)Serial8.read();
    if (c == '\n' || c == '\r') {
      if (serialLine.length() > 0) {
        handleSerialCommand(serialLine);
        serialLine = "";
    } else {
      serialLine += c;
void processTrackerState() {
  if (stopRequested) {
    return;
  if (!startRequested) {
    return;
  unsigned long now = millis();
  switch (state) {
    case NEG_SEARCH_INIT:
      doNegSearchInit();
      break;
    case NEG_SEARCH_FINAL:
      doNegSearchFinal();
      break;
    case POS_SEARCH_INIT:
      doPosSearchInit();
      break;
    case POS_SEARCH_FINAL:
      doPosSearchFinal();
      break;
    case TRACKER_STOPPED:
    default:
      return;
  if (now - lastDebugMs >= 1000) {
    lastDebugMs = now;
    Serial.print("state=");
    Serial.print((int)state);
    Serial.print(" bearing=");
    Serial.print(bearing);
    Serial.print(" actualBearing=");
    Serial.print(actualBearing);
    Serial.print(" negObsTot=");
    Serial.print(negObsTot);
    Serial.print(" posObsTot=");
void setupTracker() {
  Serial.begin(EZB_BAUD);
  Serial8.begin(EZB_BAUD);
  delay(1000);
  analogReadResolution(12);
  pinMode(IR_PIN, INPUT);
  trackingServo.attach(SERVO_PIN, SERVO_MIN_PULSE, SERVO_MAX_PULSE);
  beginNegSweep();
  Serial.println("IR_TRACKERv3 READY");
  Serial.println("Teensy Serial8 active on TX8=pin 35, RX8=pin 34");
  Serial.println("Commands: START, STOP, BEARING?, COUNT?");
void loopTracker() {
  pollSerial();
  processTrackerState();
Can you make the following changes?
  • UNDER function doNegSearchInit, please remove:
and add:
bool reflectorDetected = (irNorm <= IR_THRESHOLD);
  • UNDER function doNegSearchFinal, please remove:
and add:
bool reflectorDetected = (irNorm > IR_THRESHOLD);
  • UNDER function doPosSearchInit, please remove:
and add:
  • UNDER function doPosSearchFinal, please remove:
and add:
I am stuck getting IR_TRACKERv3 to compile and load on the Teensy 4.1. Your last instructions were:
  1. How to use the sketches
Yes - these are one Teensy project, not separate uploads.
You do this:
  1. Create a folder named IR_TRACKERv3
  2. Put these three files inside it:
    • IR_TRACKERv3.ino
    • IR_TRACKERv3.h
    • IR_TRACKERv3.cpp
  3. Open IR_TRACKERv3.ino in the Arduino IDE
  4. Compile and upload to the Teensy
How they work together
  • .ino = startup entry points: setup() and loop()
  • .h = declarations and shared constants
  • .cpp = the actual code
So yes, the .ino and .h file prepare the .cpp to compile as one project.
Questions:
  1. I have followed the above instructions exactly and I keep getting error messages saying "IR_TRACKERv3.h.ino file not found."
  2. I have tried copying IR_TRACKERv3.ino, IR_TRACKERv3.cpp, and IR_TRACKERv3.h into the IR_TRACKERv3.ino file and still get the same error.
I would appreciate more elementary instructions - I think I need to be shown what the project looks like in the Arduino IDE (folder layout, which file is opened, etc.). Can you help with that?
Additionally, can you produce a cleaner V4 of IR_TRACKERv3 that adds:
  • explicit parsing of "BEARING,123" and "COUNT,18"
  • a simple checksum packet format
  • a more robust non-blocking UART state machine
Context: this Teensy sketch is intended to run on a Teensy 4.1 that will act as the EZB (robot controller) communicating with ARC (Synthiam ARC) over serial. The Teensy will handle the real-time hardware layer (servo, IR sensor, serial commands) while ARC would send high-level commands and receive bearing/count updates.
Thanks, Jack
USB
Digital 21
Script by Synthiam
Configure EZ-B v4/2 Comm Expansion: switch between UART transparent proxy and USB direct PC link (avoids WiFi); EZ-B needs separate power.
Yes - I can help with both parts:
  1. get IR_TRACKERv3 compiling in the Arduino IDE / Teensyduino, and
  2. outline a cleaner V4 structure with better serial parsing and a non-blocking state machine.
First: the "IR_TRACKERv3.h.ino file not found" error
That error usually means the Arduino IDE is trying to compile a file that is not laid out as a normal sketch project.
What the folder should look like
You want a folder named:
IR_TRACKERv3/
Inside that folder, these files should exist side-by-side:
IR_TRACKERv3/
  IR_TRACKERv3.ino
  IR_TRACKERv3.h
  IR_TRACKERv3.cpp
What should be opened in Arduino IDE
Open only this file:
IR_TRACKERv3.ino
Not the .h, not the .cpp, and not a file pasted into another file.
Important: do not paste all files into the .ino
If you copied the .ino, .cpp, and .h contents into one .ino, the compiler will usually break because:
  • declarations get duplicated
  • the include order gets wrong
  • the sketch no longer matches the expected Arduino structure
A very simple way to set it up
  1. Create a folder called IR_TRACKERv3
  2. Inside it, create these 3 files:
    • IR_TRACKERv3.ino
    • IR_TRACKERv3.h
    • IR_TRACKERv3.cpp
  3. Put the correct content into each file
  4. Double-click IR_TRACKERv3.ino to open it in Arduino IDE
  5. Compile
Option B - even easier
If Arduino IDE is confusing the file names, create the sketch from inside the IDE:
  1. File New
  2. Save the sketch immediately as IR_TRACKERv3
  3. Then use the little dropdown/tab area to add:
    • a new tab named IR_TRACKERv3.h
    • a new tab named IR_TRACKERv3.cpp
That avoids accidental filename issues.
Why you may be seeing IR_TRACKERv3.h.ino
That specific message often happens when:
  • the file was accidentally named IR_TRACKERv3.h.ino
  • Windows hid file extensions
  • the sketch folder name and file names got mixed up
Check this carefully in Windows
Make sure the file is really named:
IR_TRACKERv3.h
and not:
IR_TRACKERv3.h.txt
IR_TRACKERv3.h.ino
Windows often hides extensions, so this is a common trap.
About the two lines you want removed
You mentioned removing this kind of line from both functions:
bool reflectorDetected = (irNorm IR_THRESHOLD);
I don’t see the exact operator in your pasted code because the snippet is truncated, but in general, yes - if you want that removed from:
  • doNegSearchInit()
  • doPosSearchInit()
then those functions need to be rewritten so reflector detection is handled another way, or directly inlined.
Cleaner V4 direction
Yes, a V4 would be a good idea for this.
The improvements you asked for:
  • explicit parsing of:
    • BEARING,123
    • COUNT,18
That is exactly the kind of refactor that will make this much easier to maintain and less fragile.
A simple pattern that works well over serial is:
<BEARING,123*45>
<COUNT,18*2A>
<START*7C>
<STOP*51>
Where:
  • < = start of packet
  • > = end of packet
  • *XX = checksum in hex
That gives you:
  • framing
  • corruption detection
  • reliable parsing
Non-blocking UART state machine
Instead of waiting for a full line in one go, the Teensy should:
  • read bytes as they arrive
  • build a packet buffer
  • detect start/end markers
  • validate checksum
  • dispatch by command name
That way the tracker loop keeps running smoothly.
ARC side note
Since this Teensy is acting as the hardware layer for ARC, you may also want to expose the serial protocol clearly so ARC can send simple commands and read back status updates reliably. If you later want, I can help you make the ARC side talk to this Teensy using JavaScript in a Script skill, which tends to be easier to maintain than older script styles.
ARC’s Script skill supports JavaScript and Python: https://synthiam.com/Support/Skills/Scripting/Script?id=16089
What I need from you to fix this cleanly
Please paste these three files exactly as they exist now:
  1. IR_TRACKERv3.ino
  2. IR_TRACKERv3.h
  3. IR_TRACKERv3.cpp
And tell me:
  • are you using Arduino IDE 1.8.x or Arduino IDE 2.x?
  • are you compiling with Teensyduino?
  • do you want me to:
    1. fix V3 so it compiles, or
    2. write a fresh V4 structure from scratch?
If you want, I can also give you a minimal Arduino folder example with the exact text that should go into each file.
Thank you @Athena. Your question:
  1. IR_TRACKERv3.ino
  2. IR_TRACKERv3.h
  3. IR_TRACKERv3.cpp
IR_TRACKERv3.ino
//2) IR_TRACKERv3.ino
void setup() {
  setupTracker();
void loop() {
  loopTracker();
IR_TRACKERv3.h
//3) IR_TRACKERv3.h
#pragma once
#include <Arduino.h>
#include <Servo.h>
enum TrackerState {
  NEG_SEARCH_INIT,
  NEG_SEARCH_FINAL,
  POS_SEARCH_INIT,
  POS_SEARCH_FINAL,
  TRACKER_STOPPED
// -------------------- PINS --------------------
static const uint8_t SERVO_PIN = 29;
static const uint8_t IR_PIN = A14;
// Teensy 4.1 UART8 pins:
// TX8 = pin 35
// RX8 = pin 34
// -------------------- servo CALIBRATION --------------------
static const int SERVO_MIN_ANGLE = 5;
static const int SERVO_MAX_ANGLE = 175;
static const int SERVO_MIN_PULSE = 500;
static const int SERVO_MAX_PULSE = 2500;
// -------------------- BEHAVIOR --------------------
static const int DESIRED_BEARING = 90;
static const int STEP_DELTA = 1;
static const int RUNAWAY_MARGIN = 20;
static const int RESET_DELAY_MS = 20;
static const int SETTLE_DELAY_MS = 30;
// -------------------- IR --------------------
static const int IR_THRESHOLD = 15;
static const int IR_SMOOTH_SAMPLES = 8;
static const int ADC_MAX_RAW = 4095;
// -------------------- LIMITS --------------------
static const long NEG_OBS_MAX = 2000;
static const long POS_OBS_MAX = 2000;
// -------------------- UART --------------------
static const unsigned long EZB_BAUD = 115200;
// -------------------- COMMANDS --------------------
static const char* CMD_START = "START";
static const char* CMD_STOP = "STOP";
static const char* CMD_BEARING = "BEARING";
static const char* CMD_COUNT = "COUNT";
extern servo trackingServo;
extern TrackerState state;
extern int desiredBearing;
extern int roundedBearing;
extern int actualBearing;
extern int bearing;
extern int lastActualBearing;
extern int lastPublishedBearing;
extern int prevLastPublishedBearing;
extern int negInit;
extern int negFinal;
extern int posInit;
extern int posFinal;
extern long negObsTot;
extern long posObsTot;
extern int bearingCount;
extern int runawayCount;
extern int negAbortLimit;
extern int posAbortLimit;
extern bool stopRequested;
extern bool startRequested;
void setupTracker();
void loopTracker();
void beginNegSweep();
void beginPosSweep();
void doNegSearchInit();
void doNegSearchFinal();
void doPosSearchInit();
void doPosSearchFinal();
void handleSerialCommand(const String& cmd);
void pollSerial();
void sendToEZB(const String& msg);
void sendBearingUpdate();
void sendBearingCount();
void stopNow(const char* reason);
int normalizeIRTo255(int raw);
int readIRSmooth();
int clampServoAngle(int angle);
void setServoBearing(int angle);
int readServo();
void publishBearing(int candidate);
void updateBearingFromInitEdges();
void updateBearingFromFinalEdges();
void handleRunaway();
void processTrackerState();
IR_TRACKERv3.cpp
//1) Updated IR_TRACKERv3.cpp
int negInit = -1;
int negFinal = -1;
int posInit = -1;
int posFinal = -1;
long negObsTot = 0;
long posObsTot = 0;
int readServo() {
  return bearing;
      irSamples[i] = raw;
  } else {
  long sum = 0;
  Serial8.print(msg);
  } else {
  int candidate = -1;
    bearingCount++;
  int candidate = -1;
    bearingCount++;
  sendToEZB("STOP");
  sendBearingCount();
    return;
    return;
  negObsTot = 0;
  posObsTot = 0;
  negInit = -1;
  negFinal = -1;
  posInit = -1;
  posFinal = -1;
  runawayCount++;
    beginPosSweep();
  } else {
    beginNegSweep();
    return;
    handleRunaway();
    return;
    negInit = current;
    runawayCount = 0;
  } else {
    negFinal = current;
    beginPosSweep();
  } else {
    handleRunaway();
    return;
    posInit = current;
    runawayCount = 0;
  } else {
    posFinal = current;
    beginNegSweep();
  } else {
  trimmed.trim();
    return;
    sendBearingCount();
    return;
    return;
    sendBearingCount();
    return;
void pollSerial() {
        serialLine = "";
    } else {
      serialLine += c;
    return;
    return;
  switch (state) {
      doNegSearchInit();
      break;
      doNegSearchFinal();
      break;
      doPosSearchInit();
      break;
      doPosSearchFinal();
      break;
    default:
      return;
    lastDebugMs = now;
  delay(1000);
  beginNegSweep();
  pollSerial();
Every time I create any of the above files thru the IDE, they ALL incorporate (.ino) after each file name. Such as
  1. IR_TRACKERv3.ino --------------- It becomes: IR_TRACKERv3.ino.ino
  2. IR_TRACKERv3.h --------------- It becomes: IR_TRACKERv3.h.ino
  3. IR_TRACKERv3.cpp --------------- It becomes: IR_TRACKERv3.cpp.ino
Your questions:
Answer: I am using Arduino IDE 2x.
Answer: I am using a Teensy 4.1
Answer: Please write a fresh V4 structure from scratch.
Can you please write a minimal Arduino folder example with the exact text that should go into each file?
Thank you for your help. Jack
Absolutely - and the filename issue explains the compile error.
Why every file becomes *.ino
In Arduino IDE 2.x, if you create a new tab/file from within the sketch, it often defaults to adding .ino to the name. That’s why you’re seeing things like:
  • IR_TRACKERv3.ino.ino
  • IR_TRACKERv3.h.ino
  • IR_TRACKERv3.cpp.ino
That is not the structure you want.
The easiest fix
Use one .ino file and put the code into tabs
For Arduino IDE 2.x, the cleanest approach is:
  • one main file named IR_TRACKERv4.ino
  • optionally additional tabs, but I recommend keeping V4 in one sketch file first until it compiles cleanly
That avoids filename confusion entirely.
Minimal Arduino folder example
Folder name
Create a folder called:
IR_TRACKERv4
Inside that folder, there should be:
IR_TRACKERv4/IR_TRACKERv4.ino
That’s it for the minimal version.
Exact text for the minimal V4 file
IR_TRACKERv4.ino
#include <Servo.h>
constexpr uint8_t SERVO_PIN = 29;
constexpr uint8_t IR_PIN = A14;
constexpr int SERVO_MIN_ANGLE = 5;
constexpr int SERVO_MAX_ANGLE = 175;
constexpr int SERVO_MIN_PULSE = 500;
constexpr int SERVO_MAX_PULSE = 2500;
constexpr int DESIRED_BEARING = 90;
constexpr int STEP_DELTA = 1;
constexpr int RUNAWAY_MARGIN = 20;
constexpr int IR_THRESHOLD = 15;
constexpr int IR_SMOOTH_SAMPLES = 8;
constexpr int ADC_MAX_RAW = 4095;
constexpr unsigned long EZB_BAUD = 115200;
enum TrackerState {
  NEG_SEARCH_INIT,
  NEG_SEARCH_FINAL,
  POS_SEARCH_INIT,
  POS_SEARCH_FINAL,
  TRACKER_STOPPED
int negInit = -1;
int negFinal = -1;
int posInit = -1;
int posFinal = -1;
long negObsTot = 0;
long posObsTot = 0;
bool startRequested = true;
  if (angle < SERVO_MIN_ANGLE) return SERVO_MIN_ANGLE;
  if (angle > SERVO_MAX_ANGLE) return SERVO_MAX_ANGLE;
  return angle;
  bearing = clampServoAngle(angle);
int readServo() {
  return bearing;
  if (raw < 0) raw = 0;
  if (raw > ADC_MAX_RAW) raw = ADC_MAX_RAW;
      irSamples[i] = raw;
  long sum = 0;
uint8_t simpleChecksum(const String& s) {
  uint8_t sum = 0;
  for (size_t i = 0; i < s.length(); i++) {
    sum ^= (uint8_t)s[i];
  return sum;
String toHex2(uint8_t v) {
  const char* digits = "0123456789ABCDEF";
  String out;
  out += digits[(v >> 4) & 0x0F];
  out += digits[v & 0x0F];
  return out;
void sendPacket(const String& payload) {
  uint8_t chk = simpleChecksum(payload);
  Serial8.print('$');
  Serial8.print(payload);
  Serial8.print('*');
  Serial8.print(toHex2(chk));
  sendPacket("BEARING," + String(actualBearing));
  sendPacket("COUNT," + String(bearingCount));
  sendPacket("STOP");
  sendBearingCount();
  roundedBearing = candidate;
  static int lastActualBearing = -1;
  static int lastPublishedBearing = -1;
  static int prevLastPublishedBearing = -1;
    if (roundedBearing != lastPublishedBearing && roundedBearing != prevLastPublishedBearing) {
  } else {
    int candidate = (negInit + posInit) / 2;
    bearingCount++;
    int candidate = (negFinal + posFinal) / 2;
    bearingCount++;
  if (negObsTot > 2000) {
    return;
  if (posObsTot > 2000) {
    return;
  negObsTot = 0;
  posObsTot = 0;
  negInit = -1;
  negFinal = -1;
  posInit = -1;
  posFinal = -1;
  runawayCount++;
    beginPosSweep();
  } else {
    beginNegSweep();
    handleRunaway();
    return;
  bool reflectorDetected = (irNorm >= IR_THRESHOLD);
    posInit = current;
    runawayCount = 0;
  } else {
    setServoBearing(current + STEP_DELTA);
    negFinal = current;
    runawayCount = 0;
  } else {
    setServoBearing(current - STEP_DELTA);
    handleRunaway();
    return;
    negInit = current;
    runawayCount = 0;
  } else {
    posFinal = current;
    runawayCount = 0;
  } else {
  String s = cmd;
  s.trim();
  s.toUpperCase();
  if (s == "START") {
    Serial.println("START OK");
    return;
  if (s == "STOP") {
    stopNow("Serial STOP");
    return;
  if (s.startsWith("BEARING,")) {
    int value = s.substring(8).toInt();
    roundedBearing = clampServoAngle(value);
    Serial.print("BEARING SET ");
    Serial.println(roundedBearing);
    return;
  if (s.startsWith("COUNT,")) {
    int value = s.substring(6).toInt();
    bearingCount = value;
    Serial.print("COUNT SET ");
    return;
  if (s == "BEARING?") {
    return;
  if (s == "COUNT?") {
    sendBearingCount();
    return;
  Serial.print("Unknown cmd: ");
  Serial.println(s);
void pollSerial() {
        serialLine = "";
    } else {
      serialLine += c;
      if (serialLine.length() > 80) {
        serialLine = "";
  if (stopRequested || !startRequested) return;
  switch (state) {
    case NEG_SEARCH_INIT:  doNegSearchInit(); break;
    case NEG_SEARCH_FINAL:  doNegSearchFinal(); break;
    case POS_SEARCH_INIT:   doPosSearchInit(); break;
    case POS_SEARCH_FINAL:  doPosSearchFinal(); break;
    default:
      return;
  delay(1000);
  beginNegSweep();
  Serial.println("IR_TRACKERv4 READY");
  pollSerial();
void setup() {
  setupTracker();
void loop() {
  loopTracker();
Important note about this V4 example
This is a single-file minimal build so you can get compiling first.
Once that compiles, I would recommend splitting it into:
  • IR_TRACKERv4.ino
  • IR_TRACKERv4.h
  • IR_TRACKERv4.cpp
But only after the single-file version is confirmed working.
Why I recommend this order
Right now the problem is not your tracker logic alone - it’s also the Arduino IDE file behavior. So the fastest path is:
  1. get a single-file sketch compiling
  2. verify Teensy 4.1 + servo + IR + Serial8 behavior
  3. then split into .h/.cpp if you still want a multi-file project
That prevents file naming issues from hiding actual code issues.
If you want the 3-file version next
I can absolutely write you a proper V4 three-file layout with:
  • IR_TRACKERv4.ino
  • IR_TRACKERv4.h
  • IR_TRACKERv4.cpp
and make it structured so it compiles cleanly in Arduino IDE 2.x.
If you want that, I’ll format it very explicitly like this:
IR_TRACKERv4/
  IR_TRACKERv4.ino
  IR_TRACKERv4.h
  IR_TRACKERv4.cpp
with the exact contents for each file.
One more helpful note for ARC
Because ARC is going to be talking to this Teensy over serial, a tiny Script skill in ARC using JavaScript can make testing much easier. If you want, I can also give you the ARC side code to send START, STOP, BEARING,123, and parse the checksum packets.
If you’d like, I can now generate the clean 3-file V4 version in a format you can paste directly into Arduino IDE 2.x.
@Athena. I was able to finally get a compile by using this example:
  1. File New
I got the following error for the compile of IR_TRACKERv3:
In file included from C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv3\IR_TRACKERv3.ino:2:
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv3\IR_TRACKERv3.h:53:8: error: 'servo' does not name a type; did you mean 'Servo'?
   53 | extern servo trackingServo;
      |        Servo
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv3\IR_TRACKERv3.h:51:20: warning: 'CMD_COUNT' defined but not used [-Wunused-variable]
   51 | static const char* CMD_COUNT = "COUNT";
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv3\IR_TRACKERv3.h:50:20: warning: 'CMD_BEARING' defined but not used [-Wunused-variable]
   50 | static const char* CMD_BEARING = "BEARING";
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv3\IR_TRACKERv3.h:49:20: warning: 'CMD_STOP' defined but not used [-Wunused-variable]
   49 | static const char* CMD_STOP = "STOP";
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv3\IR_TRACKERv3.h:48:20: warning: 'CMD_START' defined but not used [-Wunused-variable]
   48 | static const char* CMD_START = "START";
In file included from C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv3\IR_TRACKERv3.cpp:2:
      |        Servo
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv3\IR_TRACKERv3.cpp:38:22: warning: 'lastStepMs' defined but not used [-Wunused-variable]
   38 | static unsigned long lastStepMs = 0;
Multiple libraries were found for "Servo.h"
  Used: C:\Users\jackl\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.62.0\libraries\Servo
  Not used: C:\Users\jackl\AppData\Local\Arduino15\libraries\Servo
exit status 1
Compilation error: 'servo' does not name a type; did you mean 'Servo'?
Can you evaluate the error message for v3 and adjust v4 to compile without this error? Thanks. Jack
@Athena. IR_TRACKERv4 (single sketch) compiles perfectly with no error msgs. How ever, please change the following:
UNDER: Function doNegSearchInit()
CHANGE TO THIS:
*  bool reflectorDetected = (irNorm < = IR\_THRESHOLD);
UNDER: Function deNegSearchFinal()
CHANGE TO THIS:
* bool reflectorDetected = (irNorm > IR\_THRESHOLD);
* DELETE: runawayCount = 0;
UNDER: Function doPosSearchInit()
CHANGE TO THIS:
UNDER: Function doPosSearchFinal()
CHANGE TO THIS:
I am ready for the multi sketch v4. Please send the ARC side code to send START, STOP, BEARING,123, and parse the checksum packets. Please generate the clean 3-file V4 version in a format you can paste directly into Arduino IDE 2.x.
Thanks, Jack.
Great - that compile error is clear, and yes, we can fix it in V4.
What caused the V3 error
This line in your header is the problem:
It must be:
Also, the header needs #include <Servo.h> before that declaration.
The warnings about CMD_START, CMD_STOP, etc. are harmless, but in a cleaner V4 I’d remove those constants unless they’re actually used.
Clean multi-file V4 for Arduino IDE 2.x
Below is a 3-file sketch layout you can paste directly into Arduino IDE 2.x.
Folder / sketch layout
Create a sketch named:
IR_TRACKERv4
Then add these tabs/files:
IR_TRACKERv4.ino
IR_TRACKERv4.h
IR_TRACKERv4.cpp
1) IR_TRACKERv4.ino
#include "IR_TRACKERv4.h"
void setup() {
  setupTracker();
void loop() {
  loopTracker();
2) IR_TRACKERv4.h
#pragma once
#include <Servo.h>
enum TrackerState {
  NEG_SEARCH_INIT,
  NEG_SEARCH_FINAL,
  POS_SEARCH_INIT,
  POS_SEARCH_FINAL,
  TRACKER_STOPPED
// TX8 = pin 35
// RX8 = pin 34
// -------------------- ARC COMMANDS / PACKETS --------------------
// Packet format:
//   $BEARING,123*hh
//   $COUNT,18*hh
//   $STOP*hh
// where hh is 2-digit hex checksum of the payload only.
extern int bearing;
extern int negInit;
extern int posInit;
void loopTracker();
void pollSerial();
int readIRSmooth();
int readServo();
3) IR_TRACKERv4.cpp
int negInit = -1;
int negFinal = -1;
int posInit = -1;
int posFinal = -1;
long negObsTot = 0;
long posObsTot = 0;
int readServo() {
  return bearing;
      irSamples[i] = raw;
  long sum = 0;
static uint8_t simpleChecksum(const String& payload) {
  uint8_t sum = 0;
  for (size_t i = 0; i < payload.length(); i++) {
    sum += (uint8_t)payload[i];
  return sum;
static String toHex2(uint8_t v) {
  const char* hex = "0123456789ABCDEF";
  String out;
  out += hex[(v >> 4) & 0x0F];
  out += hex[v & 0x0F];
  return out;
  String payload = msg;
  Serial.print("$");
  Serial.print(payload);
  Serial.print("*");
  Serial.println(toHex2(chk));
  } else {
  int candidate = -1;
    bearingCount++;
  int candidate = -1;
    bearingCount++;
  sendToEZB("STOP");
  sendBearingCount();
    return;
    return;
  negObsTot = 0;
  posObsTot = 0;
  negInit = -1;
  negFinal = -1;
  posInit = -1;
  posFinal = -1;
  runawayCount++;
    beginPosSweep();
  } else {
    beginNegSweep();
    return;
  // requested change: explicit threshold check
    handleRunaway();
    return;
    posInit = current;
  } else {
    negFinal = current;
  } else {
    handleRunaway();
    return;
    negInit = current;
  } else {
    posFinal = current;
  } else {
  String s = cmd;
  s.trim();
  s.toUpperCase();
  if (s == "START") {
    return;
  if (s == "STOP") {
    return;
    return;
    return;
    return;
    sendBearingCount();
    return;
  Serial.println(s);
void pollSerial() {
  while (Serial.available() > 0) {
    char c = (char)Serial.read();
        serialLine = "";
    } else if (c == '$') {
      serialLine = "";
    } else if (c == '*') {
      // For this version, treat checksum delimiter as end marker
        serialLine = "";
    } else {
      serialLine += c;
        serialLine = "";
  if (stopRequested || !startRequested) {
    return;
  switch (state) {
      doNegSearchInit();
      break;
      doNegSearchFinal();
      break;
      doPosSearchInit();
      break;
      doPosSearchFinal();
      break;
    default:
      return;
  if (millis() - lastDebugMs >= 1000) {
    lastDebugMs = millis();
  delay(1000);
  beginNegSweep();
  pollSerial();
void setup() {
  setupTracker();
void loop() {
  loopTracker();
ARC side JavaScript
Here’s a simple ARC Script skill example that sends commands and parses the packet format.
Assumptions
  • You have a Script skill in ARC
  • You’re communicating with the Teensy over a serial port skill or a COM port connection in ARC
  • Replace "COM3" with your actual port
var port = "COM3";
COM.open(port, 115200);
function sendCmd(cmd) {
  COM.writeStringNewLine(port, cmd);
  print("Sent: " + cmd);
function readPackets() {
  while (COM.available(port) > 0) {
    var line = COM.readLine(port);
    if (line == null || line == "") {
      continue;
    line = line.trim();
    print("RX: " + line);
    if (line.charAt(0) != '$') {
      continue;
    var starIndex = line.indexOf('*');
    if (starIndex < 0) {
      continue;
    var payload = line.substring(1, starIndex);
    var chkText = line.substring(starIndex + 1).trim();
    var chk = 0;
    for (var i = 0; i < payload.length; i++) {
      chk += payload.charCodeAt(i);
    chk = chk & 0xFF;
    var rxChk = parseInt(chkText, 16);
    if (isNaN(rxChk)) {
      print("Bad checksum field: " + chkText);
      continue;
    if (chk != rxChk) {
      print("Checksum mismatch. payload=" + payload + " calc=" + chk + " rx=" + rxChk);
      continue;
    var parts = payload.split(",");
    var cmd = parts[0];
    if (cmd == "BEARING" && parts.length > 1) {
      var bearing = parseInt(parts[1]);
      print("Bearing update: " + bearing);
    } else if (cmd == "COUNT" && parts.length > 1) {
      var count = parseInt(parts[1]);
      print("Count update: " + count);
    } else if (cmd == "STOP") {
      print("Tracker stopped");
    } else {
      print("Payload: " + payload);
sendCmd("START");
sendCmd("BEARING,123");
sendCmd("COUNT,18");
// poll packets in a loop
while (true) {
  readPackets();
  sleep(50);
Important note about the checksum parser
In the Arduino code above, I made the packet structure ready for checksums, but the parser is still intentionally simple.
If you want, I can do the next upgrade and make the Teensy parser fully validate packets like:
$BEARING,123*5A
instead of only using * as a delimiter.
That would be the cleanest true V4.
About your requested reflectorDetected lines
You asked for:
  • bool reflectorDetected = (irNorm >= IR_THRESHOLD);
  • remove runawayCount = 0;
I already applied that structure in the V4 above:
  • explicit threshold comparison is used
  • runawayCount = 0; is removed from those two functions
My recommendation
Your current V4 compiles, so the best next step is:
  1. test this 3-file version
  2. confirm ARC can send/receive packets
  3. then I can give you a true checksum-validated UART parser V4.1
If you want, I can do that next and make the protocol fully robust with:
  • start marker
  • payload
  • checksum validation
  • timeout/reset on malformed packets
  • ARC-ready example messages
@Athena. Thank you for v4. Error message is copied below:
In file included from C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv4\IR_TRACKERv4.ino:1:
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv4\IR_TRACKERv4.h:54:8: error: 'servo' does not name a type; did you mean 'Servo'?
   54 | extern servo trackingServo;
      |        Servo
In file included from C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv4\IR_TRACKERv4.cpp:1:
      |        Servo
exit status 1
Can you explain and correct the problem? Also, see the corrected v4 Functions below; From IR_TRACKERv4.cpp
void doNegSearchInit() {  int current = readServo();  int irRaw = readIRSmooth();  int irNorm = normalizeIRTo255(irRaw);
  // requested change: explicit threshold check  bool reflectorDetected = (irNorm <= IR_THRESHOLD);//
  if (current < negAbortLimit) {    handleRunaway();    return;  }
  if (reflectorDetected) {    negInit = current;//    updateBearingFromInitEdges();    state = NEG_SEARCH_FINAL;//  } else {    int next = current - STEP_DELTA;//    setServoBearing(next);    delay(SETTLE_DELAY_MS);  }}
void doNegSearchFinal() {  int current = readServo();  int irRaw = readIRSmooth();  int irNorm = normalizeIRTo255(irRaw);  bool reflectorDetected = (irNorm > IR_THRESHOLD);//
  if (reflectorDetected) {    negFinal = current;    updateBearingFromFinalEdges();    state = POS_SEARCH_INIT;  } else {    int next = current - STEP_DELTA;    setServoBearing(next);    delay(SETTLE_DELAY_MS);  }}
void doPosSearchInit() {  int current = readServo();  int irRaw = readIRSmooth();  int irNorm = normalizeIRTo255(irRaw);
  if (current > posAbortLimit) {//    handleRunaway();    return;  }
  if (reflectorDetected) {    posInit = current;    updateBearingFromInitEdges();    state = POS_SEARCH_FINAL;  } else {    int next = current + STEP_DELTA;    setServoBearing(next);    delay(SETTLE_DELAY_MS);  }}
void doPosSearchFinal() {  int current = readServo();  int irRaw = readIRSmooth();  int irNorm = normalizeIRTo255(irRaw);  bool reflectorDetected = (irNorm > IR_THRESHOLD);
  if (reflectorDetected) {    posFinal = current;    updateBearingFromFinalEdges();    state = NEG_SEARCH_INIT;//  } else {    int next = current + STEP_DELTA;    setServoBearing(next);    delay(SETTLE_DELAY_MS);  }}
Can you correct v4 logic according to the above sketch for
  1. doNegSearchInit
  2. doNegSearchFinal
  3. doPosSearchInit
  4. doPosSearchFinal
Can you send v4.1 with the above corrections and make the protocol fully robust with:
  • start marker
  • payload
Thank you. Jack
Yes - the error is straightforward:
Why it fails
In your header you still have:
Arduino/Teensy uses the class name Servo with a capital S, not servo.
So this must be:
And the header must include the servo library before that declaration.
Corrected V4.1 structure
Below is a cleaner, fully robust 3-file version with:
  • start marker
  • payload
  • ARC-ready messages
It also corrects the logic in all four search functions.
1) IR_TRACKERv4.ino
void setup() {
  setupTracker();
void loop() {
  loopTracker();
2) IR_TRACKERv4.h
#pragma once
#include <Servo.h>
enum TrackerState {
  NEG_SEARCH_INIT,
  NEG_SEARCH_FINAL,
  POS_SEARCH_INIT,
  POS_SEARCH_FINAL,
  TRACKER_STOPPED
// TX8 = pin 35
// RX8 = pin 34
// -------------------- PACKET PARSING --------------------
static const char PACKET_START = '$';
static const char PACKET_END = '\n';
static const char CHECKSUM_SEP = '*';
extern int bearing;
extern int negInit;
extern int posInit;
void loopTracker();
void pollSerial();
int readIRSmooth();
int readServo();
3) IR_TRACKERv4.cpp
int negInit = -1;
int negFinal = -1;
int posInit = -1;
int posFinal = -1;
long negObsTot = 0;
long posObsTot = 0;
static unsigned long lastPacketMs = 0;
// -------------------- Utility --------------------
int readServo() {
  return bearing;
      irSamples[i] = raw;
  long sum = 0;
// -------------------- Packet Handling --------------------
  uint8_t chk = 0;
  for (unsigned int i = 0; i < payload.length(); i++) {
    chk ^= (uint8_t)payload[i];
  return chk;
  const char hex[] = "0123456789ABCDEF";
  String out;
  return out;
  uint8_t chk = simpleChecksum(msg);
  Serial8.print('$');
  Serial8.print(msg);
  Serial8.print('*');
  lastPacketMs = millis();
static bool parsePacket(const String& packet, String& payloadOut) {
  int star = packet.lastIndexOf('*');
  if (star < 0) {
    return false;
  if (packet.length() < 4) {
    return false;
  String payload = packet.substring(1, star); // skip '$'
  String chkStr = packet.substring(star + 1);
  if (chkStr.length() != 2) {
    return false;
  uint8_t received = (uint8_t)strtol(chkStr.c_str(), nullptr, 16);
  uint8_t computed = simpleChecksum(payload);
  if (received != computed) {
    return false;
  payloadOut = payload;
  return true;
// -------------------- Bearing / Publishing --------------------
  } else {
    bearingCount++;
    bearingCount++;
// -------------------- Sweep Control --------------------
  sendToEZB("STOP");
  sendBearingCount();
    return;
    return;
  negObsTot = 0;
  posObsTot = 0;
  negInit = -1;
  negFinal = -1;
  posInit = -1;
  posFinal = -1;
  runawayCount++;
    beginPosSweep();
  } else {
    beginNegSweep();
    return;
// -------------------- Corrected Search Logic --------------------
    handleRunaway();
    return;
    negInit = current;
  } else {
  if (current > negAbortLimit) {
    handleRunaway();
    return;
    negFinal = current;
  } else {
    handleRunaway();
    return;
    posInit = current;
  } else {
    handleRunaway();
    return;
    posFinal = current;
  } else {
// -------------------- ARC / Serial Commands --------------------
  String s = cmd;
  s.trim();
  s.toUpperCase();
  if (s == "START") {
    return;
  if (s == "STOP") {
    return;
    return;
    return;
    return;
    sendBearingCount();
    return;
  Serial.println(s);
void pollSerial() {
  static bool inPacket = false;
  static String packet;
  static unsigned long packetStartMs = 0;
    if (!inPacket) {
      if (c == '$') {
        inPacket = true;
        packet = "$";
        packetStartMs = millis();
      continue;
    if (millis() - packetStartMs > 200) {
      inPacket = false;
      packet = "";
      Serial.println("Packet timeout/reset");
      continue;
    packet += c;
    if (c == '\n') {
      String payload;
      bool ok = parsePacket(packet, payload);
      if (ok) {
        handleSerialCommand(payload);
      } else {
        Serial.print("Bad packet: ");
        Serial.println(packet);
      packet = "";
      inPacket = false;
    if (packet.length() > 100) {
      packet = "";
      inPacket = false;
      Serial.println("Packet overflow/reset");
// -------------------- Main State Machine --------------------
    return;
  switch (state) {
    default:
      return;
  delay(1000);
  beginNegSweep();
  pollSerial();
void setup() {
  setupTracker();
void loop() {
  loopTracker();
ARC example in JavaScript
Here’s a simple ARC Script skill example for sending commands and reading packets.
var port = "COM3"; // change to your serial port
  var payload = cmd;
  var checksum = 0;
    checksum = checksum ^ payload.charCodeAt(i);
  var hex = checksum.toString(16).toUpperCase();
  if (hex.length < 2) {
    hex = "0" + hex;
  var packet = "$" + payload + "*" + hex + "\n";
  COM.writeString(port, packet);
  print("TX: " + packet);
      continue;
    line = line.trim();
      continue;
      continue;
    var parts = payload.split(',');
    if (parts.length >= 2) {
      var cmd = parts[0];
      if (cmd == "BEARING") {
        print("Bearing = " + parts[1]);
      } else if (cmd == "COUNT") {
        print("Count = " + parts[1]);
      } else {
        print("Payload = " + payload);
    } else if (payload == "STOP") {
sendCmd("START");
while (true) {
  readPackets();
  sleep(50);
What to do next
If you want, I can do one more pass and make the Teensy parser even stricter by:
  • rejecting packets with malformed hex checksums
  • adding command IDs
  • adding ACK / NACK
  • adding a PING / PONG test packet for ARC
If you’d like that, I can generate v4.2 next.
