HTTP Server icon HTTP Server — Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution. Try it →
Idea: It Would Be Nice To Have Ocr
Just a thought. It would be nice for us to be able to read text from the camera. I am sure that would be very hard, however. But, just a thought . . . . in case it is just a hop skip and a jump from Glyph reading.
Also, the ADC ports have a meter for my temperature sensor. It shows up on the meter. It would be nice to have degrees F and C labels on it.
I just hooked up my PIR and it is working GREAT. I have completely tore down my Marty robot and completely rebuilt her. She is sort of the same as before but, I have the notebook in a location where I can do tel-presence. But the main thing I did was graduate to thicker servo extension cables.
I am in the process of navigation which I could never do before because of those cheap cables made the sensors unreliable. Now, I have a second chance at Navigation.
wish me luck! . . . . .
Mel
I am just wanting to display the temperature from a temperature sensor. In degrees F.
@moviemaker, there are hundreds of thousands of sensors on the market. To make things worse, each sensor model has sub-models with different ranges. Each sensor is calibrated and returns a different value. It would be impossible for me to create a control for every sensor - so instead, the ADC control allows a multiplier:)
Simply check the Datasheet for your sensor. It will specify a range of voltage and degrees.
