Custom Movement Panel icon Custom Movement Panel — Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors Try it →
Ireland
#41
Hi Robotmaker Looking for a circuit to give the the Sparkfun mp3trigger card a line output level, it comes with low level suitable for small speaker.I require the output to feed into a high power audio amp. Any assistance would be much appreciated. Thank you in Advance Pat
https://www.sparkfun.com/products/11029
#42
@robotmaker
On the application schematic shown on the PDF for the an6884 chip the audio would hook to the 2.2uf capacitor?
#43
@rgordon yes,that is where the audio goes
@bravia you need a audio boost amp,mostly all it is a gain amp using a chip and few resistors
#44
Thanks. I am ordering the chips today.
#45
@robotmaker
On an earlier thread in the Hardware section of this forum I posted a link to a site that talks about controlling dc gear motors like a servo. Turn DC Gear Motor into servo
Do you have a step by step tutorial for something like this?
#46
@RGORDON not really good at that,but pretty simple made so many of them ,all you need is servo board from a cheap FUTABA S3003 FROM china,remove the motor and pot and add your own motor and pot a attached to motor,now if need more ams then the chip on S3003 ,take 2 chips and add together in parallel if need more cicuit use a h-bridge,if you have problems wiring the h-brigge i can help you
#47
@ Bravia,
Sparkfun has some.....are these still too little gain?
Audio Amp
If they are too weak... look into some car electronics boosters. I have line level audio signal booster I bought from Radio Shack several years ago, 12V Power supply of course but works pretty good. I think it was less than $20.
v/r
Kevin
#48
KEVIN thats not what he is looking for ,most stereo iputs are 1 k impedance and speakers are 8 oms so you need a matching trasfomer 8 ohms to about 1k radio shack has one for it,i alsmost forgot about it audio matching transfomer
it matches speaker to audio input if stereo you need 2 ,one for each speaker
