Conversational Menu icon Conversational Menu — Voice menu tree to navigate options and run scripts on ARC robots. Multi-level, customizable prompts, speech I/O, timeout and repeat/back. Try it →
Resolved Resolved by Rich!
If-Then Programming
Can anyone give me info on how to program an If-Then sequence? Ex. If the robot sees a red ball, it will stop, if it sees a green one, it will go forward. Also a screenshot of the programming would be helpful. Thanks!
I have covered IF statements in a few topics, I'll list them in a sec. But to answer this question is very simple;
First you need to make sure you have the camera control set up for colour detection, this will give ARC the global variable called $CameraObjectColor
Then your script would need the following IF statement
IF($CameraObjectColor = "Red")
  Stop()
ELSEIF($CameraObjectColor = "Green")
  Forward()
ELSE
  # Neither colour detected
  Print("No colour detected, awaiting colour to proceed")
EndIf
Thanks! I will test that out.
There are dozens of example projects in ARC that demonstrates everything.
  1. Start ARC
  2. Press OPEN file the FILE menu
  3. Press the EXAMPLES button
You will now see sub directories for SCRIPT examples and FUNCTION examples
I still keep forgetting about the examples already in ARC, must remember next time:)
Thanks for the help! I am excited to test it out!
