Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
I am new here and I have a problem. When I type in the robot port for my robosapian v1 that is D1 it says password I am wondering what they mean by password thanks in advance.:)
Hi! And welcome
You connect to the EZ-B over the COM port that was detected. There is a menu option called "TUTORIALS" on this website. Look up and you'll see it across the menu bar. Press that button and follow the tutorials to see how to use the EZ-B:)
Also, every control has a ? next to the X close button. If you press the ?, you will be directed to a help/tutorial page for that control. Press the ? button on the RoboSapien Movement Panel control and you will be directed here: https://synthiam.com/Tutorials/Help.aspx?id=175
Watch the tutorial video for the RoboSapien Movement Panel.
Do you have a video for if you want to controll the robot without any add ons ? Thank you for the previous answer also when I connect to and type in D1 it says password
