File Manager icon File Manager — Displays files currently open for reading by scripts, shows only read-opened files, helps diagnose read/write locks and file access errors. Try it →
Image From Radar Window
i use an ping sensor with the radar window.do i cant see the red line, it makes ,just a chort piece.is this correct ? also can i use 4 ping sensors in one project ?
thanks any one
This display seems to indicate "beyond range". Connect only one sensor to the Control. Ultrasonic sensors need a hard surface background to reflect off of. When testing use the floor, ceiling, or a wall.
hi robojack
can i use 3 ping controls in a project ? how can i change the beyond range thing?
thanks
