Notepad icon Notepad — Notepad for ARC: store project notes and connection details in a themed window Try it →
Important Questions For Ez Professional Users
first im not good in english though sorry for this i want to make some tasks with my robot so i ask can i use ez to do
1- i iwill connect xbee model or any 900mhz model on my pc and connect it to second xbee and i will programe xbee to connect to third xbee that iwill connect to ez board insted of bluetooth i do this as i need very long rang control and i cant use internet as no internet in that place so i must use 900mhz so can i do this with ez board
2-if i wll use singl board computer to controt ez board the problem that i want very small board so i found this boards
first is 7*7cm very small and run run windows 7 www.viaembedded.com/en/products/boards/1572/1/QSM-8Q90.html
second is EPIA-P910 10cm x 7.2cm
www.viaembedded.com/en/products/boards/1950/1/EPIA-P910.html
third is ETX-8X90 www.viaembedded.com/en/products/boards/1970/1/ETX-8X90.html
all run win 7 and i see that i can control ez throug usb can i do this
and is ther are any other boards that can run ez programe on it but at similer dimentions as the three need configration and need heat disppasions and other things
smllest is the best as i planing in future to connect it to micro cotroller of ez and make very small board that contain all in very small board can do this also
3-if iconnec to ez by xbee like in my first qestion and connect the ez board by single board computer throug usb so ez board now connected by 2 methods in same time( xbee +pc) (usb + single board computer) can i do this
4- can i use ez ports like any micocontroller like if specifi data get from xbee then do the task that i want
also can i make 2 ez boards connect each other like any 2 micro controllers with xbee to excahnge data
can i connect camera throgh 12c
5-can i use all function that in ARC throgh vb sdk
and contro all ports as example if i connect 12c camera to 12c port in ez what code in vb for this
Another idea i had for awhile is to have website selling robotic sensors of every type and have a some i made for too,it will take awhile,
Mostly to finish some of my designs and then have the pcb's out to be made
