BN-880 GPS Compass icon BN-880 GPS Compass — Standalone autonomous navigation using Beitian BN-880 GPS/Compass with real-time map waypointing and offline map caching; requires Arduino. Try it →
Resolved Resolved by Athena!
Inconsistent UART Data Transfer Issue
Hello ,
I am experiencing inconsistent UART data transfer from the EZ-B v4 to an Arduino Mega 2560. Single-byte transfers are very consistent between these two devices, but when I attempt to transfer 8 bytes, the reliability decreases significantly. I have attached samples of JavaScript and C++ code that I am using. Could you please examine this code and provide recommendations to increase the reliability of the data transfer?
Thank you very much.
Jack
JavaScript Code:
UART.initHardwareUart(0, 9600, 0);
sleep(10);
var pathTotalDistance = getVar("$pathTotalDistance");
var pathEndpointDistance = getVar("$pathEndpointDistance");
var oppositeDistance = getVar("$oppositeDistance");
var actualCourse = getVar("$actualCourse");
var desiredCourse = getVar("$desiredCourse");
var highByte = (pathTotalDistance >> 8) & 0xFF;
var lowByte = pathTotalDistance & 0xFF;
UART.hardwareUartWrite(0, [highByte, lowByte]);
print("Sending pathTotalDistance high byte: " + (pathTotalDistance >> 8));
print("Sending pathTotalDistance low byte: " + (pathTotalDistance & 0xFF));
print("pathTotalDistance: " + pathTotalDistance);
var highByte = (pathEndpointDistance >> 8) & 0xFF;
var lowByte = pathEndpointDistance & 0xFF;
print("Sending pathEndpointDistance high byte: " + (pathEndpointDistance >> 8));
print("Sending pathEndpointDistance low byte: " + (pathEndpointDistance & 0xFF));
print("pathEndpointDistance: " + pathEndpointDistance);
var highByte = (oppositeDistance >> 8) & 0xFF;
var lowByte = oppositeDistance & 0xFF;
print("Sending oppositeDistance high byte: " + (oppositeDistance >> 8));
print("Sending oppositeDistance low byte: " + (oppositeDistance & 0xFF));
print("oppositeDistance: " + oppositeDistance);
UART.hardwareUartWrite(0, [actualCourse]); // Send as one byte
UART.hardwareUartWrite(0, [desiredCourse]); // Send as one byte
print("Sending actualCourse: " + actualCourse);
print("Sending desiredCourse: " + desiredCourse);
setVar("$actualCourse", (Servo.GetPosition(17)));
halt();
C++ Code:
long pathTotalDistance = 0;
long adjacentRemainingDistance = 0;
long pathEndpointDistance = 0;
float oppositeDistance = 0;
float desiredCourse;
long actualCourse;
float diffCourse = 0;
float lastDiff = 100;
int lastIncomingByte;
int run = 0;
void setup() {
    Serial3.begin(9600); // Communication with EZ-B
    Serial.begin(9600);  // Debugging via Serial Monitor
void loop() {
    if (run == 0) {  // State of RUN when the robot has yet to begin movement towards the reflector.
        if (Serial3.available() >= 8) {
            // Read and store bytes for pathTotalDistance
            byte highBytePTD = Serial3.read();
            byte lowBytePTD = Serial3.read();
            pathTotalDistance = (highBytePTD << 8) | lowBytePTD;
            // Read and store bytes for pathEndpointDistance
            byte highBytePED = Serial3.read();
            byte lowBytePED = Serial3.read();
            pathEndpointDistance = (highBytePED << 8) | lowBytePED;
            // Read and store bytes for oppositeDistance
            byte highByteOD = Serial3.read();
            byte lowByteOD = Serial3.read();
            oppositeDistance = (highByteOD << 8) | lowByteOD;
            actualCourse = Serial3.read(); // Read and store actualCourse
            desiredCourse = Serial3.read(); // Read and store desiredCourse
            // Print the above received parameters
            Serial.print("pathTotalDistance: ");
            Serial.println(pathTotalDistance);
            Serial.print("pathEndpointDistance: ");
            Serial.println(pathEndpointDistance);
            Serial.print("oppositeDistance: ");
            Serial.println(oppositeDistance);
            Serial.print("actualCourse: ");
            Serial.println(actualCourse);
            Serial.print("desiredCourse: ");
            Serial.println(desiredCourse);
            delay(10);
            // run = 1;
I look forward to your insights on improving the reliability of this data transfer process.
Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent.
Arduinocoms by ShadowStudios
EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control
I can tell you right away what's wrong. This..
You're checking for more than 8 bytes available. So if there's 9, or 10, because the loop is faster than the uart transmission speed, the read will get out of sync. You're wanting to send "packets" it looks like. A packet would normally have a header and a byte length, but at the least, it would need header with a known number of bytes. Now, if that's the only "packet" you're sending, over and over, then you can assume the byte length.
I'd use MOD to ensure there's packets...
 if (Serial3.available() && Serial3.available()  % 8  == 0) {
That will tell you if there's at least one packet. @athena, what do you think?
Hello Jack,
DJ_Sures has pointed out a crucial aspect of your code that could be causing the inconsistency in your UART data transfer. Let's break it down and see how you can improve the reliability of your data transfer between the EZ-B v4 and the Arduino Mega 2560.
Key Points to Consider:
  1. Packet Structure:
    • Ensure that your data is structured in packets. Each packet should have a consistent format, possibly including a header, data length, and a checksum for error checking.
    • This helps in identifying the start of a new packet and ensures that the data is read correctly.
  2. Buffer Management:
    • As DJ_Sures mentioned, you should check if the available bytes are a multiple of your packet size. This ensures that you are reading complete packets.
    • Use a condition like if (Serial3.available() % 8 == 0) to ensure you have a complete packet before reading.
  3. Synchronization:
    • Consider adding a header byte or sequence to your data packets. This helps in synchronizing the start of a packet, especially if the data stream gets out of sync.
    • For example, you could start each packet with a specific byte value that is unlikely to appear in your data.
  4. Error Checking:
    • Implement a simple checksum or CRC to verify the integrity of the data received. This can help detect errors in transmission.
  5. Timing and Delays:
    • Ensure that there is enough delay between sending packets to allow the receiver to process the data.
    • You might need to adjust the delay() in your Arduino code to match the data processing speed.
Example Adjustments:
JavaScript Code:
sleep(10);
// Example of adding a header byte
var header = 0xAA; // Arbitrary header byte
UART.hardwareUartWrite(0, [header]);
// Send data as before
// Repeat for other data...
C++ Code:
void loop() {
    if (Serial3.available() >= 9) { // Adjusted for header + 8 bytes
        byte header = Serial3.read();
        if (header == 0xAA) { // Check for header
            // Print the received parameters
By implementing these changes, you should see an improvement in the reliability of your UART data transfer. If you have any further questions or need additional assistance, feel free to ask!
Athena's suggestion is more scalable if you're adding more protocol packet types of varying length and data. My suggestion would only work if you're always sending the same packet length of your protocol that you're inventing. So if you wanna scale it, use athena's answer. If you think it would always be the same information and same packet length then you can use mine.
Hello @Athena and @DJ, Thank you so much for your input.  I was able to get the following C++ code to work.  It became very reliable once I removed the "print" commands out of the "UART.write" sequences.
void loop() {
I've tried your suggestion:
but I am unable to get it to run.  Could you please insert your recommended code into the sample above for me?  Could you please explain what the following code means?
I know it's late for you, so I'll check back in tomorrow morning. Thank you so much. Jack
Hello Jack,I'm glad to hear that you've made progress with your code! Let's clarify the use of the modulo operator (%) in the context of checking for complete packets and integrate it into your existing code.
Explanation of the Modulo Operator in This Context:
  • The modulo operator (%) is used to find the remainder of a division operation.
  • In the context of checking for complete packets, Serial3.available() % 8 == 0 ensures that the number of bytes available in the buffer is a multiple of 8. This means you have a complete packet to read.
  • If the remainder is 0, it indicates that the buffer contains a complete set of bytes that matches the expected packet size.
Integrating the Modulo Check into Your Code:
Here's how you can integrate the modulo check into your existing loop:
void loop() {
    // Check if there are at least 9 bytes available (1 header + 8 data bytes)
        // Check if the number of available bytes is a multiple of 8
        if (Serial3.available() % 8 == 0) {
            if (header == 0xAA) { // Check for header byte
Key Points:
  • The if (Serial3.available() >= 9) ensures that there are at least 9 bytes available before attempting to read a packet.
  • The if (Serial3.available() % 8 == 0) ensures that the number of available bytes is a multiple of 8, indicating a complete packet.
  • The header byte is checked to ensure synchronization with the start of a packet.
By using this approach, you can ensure that your code only processes complete packets, which should improve the reliability of your data transfer. If you have any more questions or need further assistance, feel free to ask!
void loop() {
if (run == 0) {  //State of RUN when robot has yet to begin movement towards the reflector.
       // if (Serial3.available() % 8 == 0) {
// Continue with the rest of the data
Hello @Athena, Thank you for your continued support.  I was able to get MOD to run, just not reliably.  I occasionally have other UART data being sent, and while it is in the buffer, may initiate a rejection for the 8 bytes.   So far, the above code runs well, so thanks again @DJ and @Athena! Jack
Hello Jack,Im glad to hear that your code is running well! The occasional rejection you mentioned could be due to other UART data interfering with your packet structure. Here are a few additional tips to help manage this situation:
Additional Tips for Managing UART Data:
  1. Buffer Flushing:
    • Before starting to read a new packet, consider flushing the buffer to remove any unwanted data. This can be done by reading and discarding bytes until you reach the header byte.
  2. Unique Header:
    • Ensure that the header byte (e.g., 0xAA) is unique and unlikely to appear in other data. This helps in correctly identifying the start of a packet.
  3. Timeout Mechanism:
    • Implement a timeout mechanism to prevent the code from waiting indefinitely for a complete packet. If a complete packet isn't received within a certain time, you can reset the buffer and start over.
  4. Error Handling:
    • Add error handling to manage unexpected data. If the data doesn't match the expected format, you can discard it and wait for the next packet.
  5. Separate Channels:
    • If possible, use separate UART channels for different types of data to avoid interference.
Example of Buffer Flushing:
Here's a simple way to flush the buffer before reading a new packet:
void flushBuffer() {
    while (Serial3.available()) {
        Serial3.read(); // Discard any unwanted data
void loop() {
    if (run == 0) {
        // Flush the buffer before starting to read a new packet
        flushBuffer();
By implementing these strategies, you can improve the reliability of your UART communication even when other data is present. If you have any more questions or need further assistance, feel free to ask!
Hello @Athena, So, in the last post you suggest code that flushes the buffer before checking if (Serial3.available() >= 9).   As this loops, wouldn't it flush the packet before it could be read?  Does Buffer Flush empty the entire buffer? Thanks Jack
