Intel Realsense D435i icon Intel Realsense D435i — Connect Intel RealSense depth cameras to ARC NMS for depth-based distance detection, point-cloud mapping, video streaming, and navigation telemetry. Try it →
Increase Volume On Windows 10 Mic
Since I installed Windows 10, volume on the mic does not seem to be adjustable. Volume is low. I have to talk lould to get the computer to hear me. I looked online and a lot of people are having this problem withe MS 10. It is the same with all mics.
Any ideas would keep me from loosing my voice.
Thanks
Ellis
Thanks.
Alan, I did select my Bluetooth headset mic as the default microphone device but I set my Bluetooth speaker to be my Bluetooth speaker default device. Did I do that incorrectly. If yes, I do not get any mic or audio if i do not set each item to be its own default device.. When I first set this up windows asked me if I wanted to select the headset mic for mic and my Bluetooth speaker for audio. I said i did. Am I doing this wrong?
@Ellis
Did you find the issue ?
@Ellis,
Check my plugin AudioToolbox, you can confirm and set the default input and output devices.
You can use EZ-Script to change output/input devices:
#SetDefault takes in consideration the device type (input or output)
#Set device 0 as default
ControlCommand("AudioToolbox  plugin", "SetDefault", 0)
SayWait("Hello Device 0")
#Set device 1 as default
ControlCommand("AudioToolbox  plugin", "SetDefault", 1)
SayWait("Hello Device 1")
ps: only one space between AudioToolbox and plugin
ptp
Thanks for the plugin.
I didn't know it was out there. I will install it and see if it will solve my problem.
Thanks for posting it.
Ellis
