Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
Saudi Arabia
Indoor Navigation (Dj)
Dear Dj,
Can the ez-robot navigate inside the building, meaning can we use map navigation to enable the ez-robot to navigate independently, also can we give a wireless command to the ez-robot.
Ez3 be uses blue tooth and ez 4 uses wifi .. commands from the user and/or ARC software flow constantly back and forth to the EZ board... so yes, of course to your second question. Indoor navigation is possible, but you the user will have to figure out how to do it. Wheel encoders is one example and camera using QR codes is another . Saying that, rumour has it DJ is currently working on a different camera based indoor navigation system that is said to be released at a yet to be determined future date.
Saudi Arabia
Thank you Richard
