User Defined Function Example icon User Defined Function Example — Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent. Try it →
Info On Manual Moving Servos And Recording?
I saw in a thread, but don't remember a function in an ARC Auto Position skill (That means nothing as my brain suffers from rot and when I disappear for work for months on end I miss alot of added features). I read this thread :
Quote:
...manually move the servos or create custom movements by recording and playing back servo positions.
...and if I understand correctly:
  1. Is it possible to physically move standard servos into a position and then record those positions using auto position? ( is this a modified servo ie soldiering wire to the pot? Or just with regular servos?)
  2. If so, can you choose which servos to record and which ones not record, so as not destroy other servo motions? Example, I want to manually move and record positions a robot arm ( which might include 4 servos). But, I don't want it to overwrite the positions of say the rest of the of the robots motions like body, head legs etc. How do I isolate just the servos i want to record.
  3. If this is not a feature, disregard this question and thread.:)
Yes, you can manually move standard servos into a position and then record those positions using the Auto Position robot skill in ARC. This feature is called "Pose & Record". You do not need to modify the servo or solder a wire to the pot.
To choose which servos to record and which ones not to record, you can use the "Frame" feature in the Auto Position robot skill. A frame is a snapshot of the positions of all servos at a given time. You can create a new frame and then adjust the positions of the servos you want to record. The positions of the other servos will not be affected.
Here's how you can do it:
  1. Open the Auto Position robot skill in ARC.
  2. Click on the "Config" button to open the configuration menu.
  3. In the "Frames" tab, click on the "New Frame" button to create a new frame.
  4. Select the servos you want to record from the list of servos.
  5. Manually move the selected servos into the desired position.
  6. Click on the "Pose & Record" button to record the positions of the selected servos.
Remember, the Auto Position robot skill is a powerful tool for creating complex movements and gaits for your robot. You can create multiple frames and then sequence them together to create an action. You can also adjust the speed and delay of each frame to fine-tune your robot's movements.
For more detailed instructions, you can refer to the Auto Position robot skill tutorial in the support section on the Synthiam website.
#3   — Edited
@Athena To manually move the selected servos I would have to release just the servos I want to pose, correct?
Thanks Jer! No that one, I am fairly competent at! Lol.
Are you looking for inverse-kinematics type stuff, like DJ's live hack of puppeting JD?
@jer, No not looking at telemetry stuff from that hack night. Just looking under the hood to understand how Auto Position detects servo positions in athenas description from above. I don't think I ever remembered the use case of hand moving the servos into position then snapping a frame for positional data.
@Athena To move the selected servos I would have to release just the servos I want to pose, correct?
Yes, that's correct. To manually move the servos into the desired position, you would need to release them first. This can be done in the Auto Position robot skill in ARC. Here's how:
  3. In the "Servos" tab, select the servos you want to move.
  4. Click on the "Release" button to release the selected servos.
  5. You can now manually move the released servos into the desired position.
  6. Once you have positioned the servos, you can use the "Pose & Record" feature to record the positions.
Remember to be careful when manually moving the servos. Make sure not to force them or move them beyond their limits, as this could damage the servos.
