SSC-32 Servo Controller icon SSC-32 Servo Controller — ARC integration for SSC-32 servo controllers via PC COM or EZ-B/Arduino UART; maps V0-V31, configurable baud, enables servos in ARC skills. Try it →
In your connection or ini script you can call an Auto Position frame...
ControlCommand("Auto Position", AutoPositionFrameJump, "KDstand")
If you use the above example you will need a frame called "KDstand" in your Auto Position control. You don't have to use the name KDstand, you can call it whatever you want as long as there is a corresponding frame named after it...
or you can do it the hard way.... You can set KD's servos one by one...
servo(D0,90) # these numbers you'll need to change them for the proper pose
servo(D1,120)
servo(D2,80)
servo(D3,130)
etc....
rr
ok i make a frame how i want che will stand.
thanks
Good, you create the frame... What did you call it?
Have a look at the JD example, it does exactly what you are asking.
rr kd stand.and che waves say hi am kd. i have to adjust the rgb in head seems not right. then i post a video.
rich
ah thank you
