Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
in the init i can see the servo's d1 and d0 are set slower. i try to ad servo id d2 and d3/d7/d4 but they dont slow down. when jd goes in to calibrate postion it go's so almost violently fast. can this be changed ?
thanks anyone
does they need to be set like this ?
(D0, 4) (D1, 4) (D2, 4) (D3, 4) (D4, 4) (D7, 4)
  1. I don't know what those brackets and numbers are referring to
  2. you cannot change the speed of first time servo initialization because the servos have no previous position
choulders&upper arms D4&D7&D2&D3 in chest
when i set servo first like the grippers ,would it work then, to slow them down.
