Python Native icon Python Native — Run real CPython in ARC with full package support, camera access, ARC APIs, and bidirectional robot control. Try it →
Thingiverse YouTube
Inmoov Heavy Head And How Do Other Inmoovers Cable Their Robots?
Hi everyone Very interested in how you all approach the InMoov arm wiring and hiding the cables between arms and torso. Very interesting how you wired it Merne.
Also I have the speaker in the mouth and find that head settles forward on power down and tends to pull the neck out of the neck socket [bob houston style neck]. have a great weekend lorn
Thanks 3dGuy;  I will definately give the elmers glue idea a try, is it easy to clean up afterwards. the hairspray is easy,  just clean with hot water. @mayaway  Yes the arm fully extends.  I will have to make a video about the hands.  hard to describe you will have to see. you don't have to reprint the original hands.
#26
Thanks 3dGuy; I've been using CubeStick for $9 USD a bottle but it lasts a long time. I print mostly ABS on a 60*C Bed - I've wondered about good alternatives.  @nallycat oh do! on vid of the hands - their action could certainly be improved upon. The original setup is just fussy. I've thought about a lead screw linear drive solution for there too. It sounds like you do have a powered flexion against a spring loaded extension in the fingers?
