Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
Inmoov Robot, How With Ez-b Robot Controller., ?
Inmoov Robot, How With Ez-B Robot Controller., ?
Hello Ezrobot Community, All,
I'm wanting to test InMoov Robot using EzRobot but very unsure of what parts I need to get in the shop, are you able to assist please?
  1. Do I get the whole EZ-B development kit? or just the wifi robot controller is enough? but then I already have a 6V output battery pack, will this be sufficient to power up the EZ-B robot controller and the 5V servos (which I currently use..)? or I need to get the battery in the shop?
  2. Do I need the inline 5V regulator? (my servos runs at 5 volts)
  3. If I can use my 6V output battery pack, do I need to get the alternate power adapter? (from the shop)
I just want to do basic test in controlling my servos with EZ-B.., testing min and max turning angles of the motors,
Thank you for your assist,
Kind Regards, Roger
Hi @Perry_S,
Yes I need help thank you very much, I'm waiting for response on my last reply 3 days ago, and still struggling sorry,
Here is my query again,
  1. if I get this one for the bus bar to power up the servo motors: https://www.performance-world.com/Electrical-Bus-Bar-p/321322.htm (bus bar) , will this work with my 6Volt 12Ah SLA battery? (attached earlier on.)
  2. And does that mean each point on this bus bar connects to one servo motor only?
  3. I tried searching on ebay as well and saw this one: https://www.ebay.com.au/itm/1-Set-Power-Distribution-Board-With-Status-LEDs-for-DC-and-AC-Voltage-Everest/172542511803?epid=1591562533&hash=item282c55cabb%3Ag%3AbkUAAOSwA4dWMDW6&_sacat=0&_nkw=dc+power+distribution&_from=R40&rt=nc&_trksid=m570.l1313
Will this work for the servo motors, and works same as the bus bar above, one point to power up one servo motor only ?
  1. or do you have any recommendations? I'm scratching my head around, and I'm planning to get the EzB tiny version for the head,
Thank you for your help!
#26
@dory, Either one of those bus bars will work, get 2 of them, one for the positive leads and one for the negative leads. You can connect multiple servos to each point. I put 2 EZBv4/2's on the back of my InMoov and run everything with them.
@bhouston, thank you for your reply.
I had tested again connecting EZBV4 to my 6 volt SLA battery, it works by setting the minimum voltage, however I faced two issues,
  1. there are distorted noise/sounds coming out of the EZBV4, is there a way to resolve this noise? (when connected to my 12 Volt battery, there was no distorted noise).
  2. I can connect to the EZBV4 wifi, however, it drops off from time to time, it has an exclamation mark on it, does it mean I have to connect the EZBV4 to my home wifi for it to work properly?
Thank you for your help,
