Kinect Xbox 360 Depth Mapping icon Kinect Xbox 360 Depth Mapping — Converts Xbox 360 Kinect depth frames into NMS obstacle scans for ARC path planning, SLAM, and obstacle avoidance. Try it →
Inmoov With Bosch Motors
I have decided to jump into 3D printing and build a version of the Inmoov robot, here is the printer that I am going to buy, it looks a good spec.
www.dream3d.co.uk/product/ultimaker-2-desktop-3d-printer-2/?gclid=CJHR7aDloMUCFfMZtAodTU0Ang
I (personally) have no CAD knowledge, but I would like to convert the arms to the Bosch drives. They would be much more powerful (torque) than the existing servos, being virtually totally silent (I noticed the servo noise in @Aerius video that there was quite a loud holding buzz). The Bosch units already have a worm driven gearbox built in and also a feedback potentiometer. I think the Bosch units would greatly improve the Inmoov arms if a conversion can be done to allow for these these to be used with the current design.
As you have some Bosch drives, David and Richard R what do you guys think?
Tony
#25
The Bosch motors label says BOSCH VMC 12V 120804 3 (d5) 0 132 801 158 3 made in malaysia (905) MF116880-1040 DEF LHD VW Audi 4B2 820511 K
These motors have a pot, motor and gears. There is not a controller board. In order to use the servo, you have to use Tony's PIC, A Sabertooth or an H-Bridge.
#26
@All
These Bosch motors are a bummer. I got a few from @Dave and @Tony and they work so well...and they're strong. However, I can't get more of them...i tried to place a semi-big order but if I can't get them easily there's no point of using them on my builds, since I'm planning on mass-producing.
They're awesome though. Very quiet and low power consumption. Plus the main pain on my builds is getting the potentiometers to work right with the motors...this little Bosch unit has it all inside nice and neat.
#27
The history of these Bosch drives is Pat (Bravia) first bought my attention to them being sold on ebay some time back, I got a few to try out and was so impressed that I did a deal with the seller to buy a large quantity at only five quid each. These were for future production runs of the ALTAIR robots. I also designed a custom circuit and PIC to act as a compact servo controller for them to use in the production robots. I checked a few weeks back and the seller is no longer selling them.
I have so far given away over 40 Bosch drives all over the World free of charge and just checked the postage alone has cost me over 200. I do now need to start conserving what I have left for the first ALTAIR robot production runs - I am happy to supply Bosch drives and custom controllers to David as he may (hopefully) be converting the Inmoov .stl files to use the Bosch units and will be sharing these with me, so this is my way of saying thanks.
Rex found them in the US, but the cost is higher than I paid.
Search for Heater A/C Air Flap Control Motor - 4B1 820 511 K 98-05 Audi A6 S6 RS6 Allroad
Hope this helps
Tony
#28
as a status update, I have made an STL of the bosch motors and am trying to cut out the existing stl for the shoulders to fit this stl in. I have discovered that I am not as good as I once was but am working on the conversion still. This is going to take me a bit of time. I am working on this though.
#29
Richard R, are you interested in the motor base or just the fiberglass leg section? The EZ:1 robot weighs in at just over 40lb (with batteries) and the locomotion is fine with the drive motors that I used.
Looking at the Inmoov, I am wondering if my base/leg section may be too small for the Inmoov upper body, here are the build dimensions.
Richard, what do you think? I may need to get a larger leg section fabricated for the Inmoov.
Tony
#30
@Tony... inmoov's lower base (the last stl files to be release) is 230mm(wide) x 170mm(deep) so by the looks of it, it might sit nicely on the top of your base/legs.... It may need a wider base (at ground level wheel base) due to the inMoov being rather top heavy... However, you say you have about 40lbs of weight in the base so maybe?
It also might look disproportionate due to the inMoov being as large as a small adult... So maybe you will need a wider wheel base and a taller leg section?
#31
Thanks for the info Richard, The whole EZ:1 robot is 40lb (not just the base). The EZ:1 is 4 ft high, would you say that the Inmoov would be taller than this as a small adult size?
From what I can see, I guess the Inmoov probably needs to be around 5ft to look right, so the leg section may need to increased (taller) as you have determined.
Tony
#32
@Tony... I would say so...Just over 5ft total sounds about right....
