I have purchased 2 ezb’s and was wondering two things. Where Can I mount them. And how do I connect both at once so the ARCs can move in synchronization.
3dfixer
— Edited
Drone Collision
— Add HC-SR04 ultrasonic sensors with an EZ-B to AR Parrot Drone v1/v2 for collision detection and avoidance
Very nice and affordable 3d printer about to be ordered. For the ABS Filament is it 1.75 or 3.00 which one is recommended I'min the us not sure if theres a difference or not thanks Paul
I use a 1.75 mm filament. I have no experience with 3mm filament. I think the result will be the same. What's important is what type of 3D printer you use. Drupp
Also I noticed that some of you are using a tablet in the back. I know Ez Robot has and App and I'm guessing that is used for all the robots files and so he and or she can operate without having to be attached to a Desktop computer or laptop?
I have no experience with it. It would be good if someone described a solution here. The variation is more and it would be interesting to do some sort of common solution. Drupp
Hi @RedDragonManor
Take a look at the information posted in the 3D printing section. A lot of good info and advice about printing is there.
Ron
Ok thanks and its a flsun I3 3d Printer Auto-level Heated Bed 300300420 mm
Hello Again everyone. Got a couple of quick questions for our inmoov. For Hardware connections. First off were two weeks away from ordering our 3D Printer the seller is just waiting for our payment. So I'm trying to go ahead and get and idea for everything thing else. I already know how many and what servos I need already made a list for that. Were going to use two ezb4's with one camera. One is for one side of the robot and the other is for the other side. I already know how to connect them and get them hooked up. I understand that part of things. My questions are for the tablet, the big battery pack and the USB power Strip. Were can I buy and or find the Big black battery pack I see on some of you all's inmoovs and what do I hook it up to and how. for the Tablet I know it will hook up to the USB Power Strip and where does the USB Power strip hook up to for power. I know . I know the robot will have to plug into the wall at some point for charging . I'm just trying to make her as autonomous and mobile as I can. Without having to be wired to a desktop or laptop to run and function. The Hardware I had questions about. I'm assuming that's all I need to get everything going. Any help and pictures would be graciously appreciated Thanks yous truly Paul
Don’t use an ezb for each side. The Auto Position control is what defines animation actions. You can only control one ezb per Auto Position control due to the way the servo control timing works. Split an ezb for head and fingers and another for arms etc
