Rubik's Cube Solving Robot icon Rubik's Cube Solving Robot — Control a custom ARC robot to manipulate and solve a Rubik's Cube using calibrated arms and grippers; integrates with Thingiverse build. Try it →
Instructable - 0 -24 Volt Adjustable Power Supply How To :)
Hello guys this is a improment over the past tutorial posted for converting a PC power supply to be a bench 12 volt supply. This tutorial uses the same computer PSU to make a adjustable 0 to 24 volts. This means testing equipment of different voltages will be much easier. Now you don't need to hunt down a ad adapter and cut it up only to find it's not really the voltage you needed.
#17
I just jump the green and black wire to power on my old PC power supplies...
Sweet trick RR. I remember years ago reading about this jumper method. Back then I never really understood what wires to jumper. This is a lot better then having a big 3.5 floppy drive strapped to the top of my old ATX like a big humpback. LOL. Thanks. ;)
New Zealand
#19
I have mine installed on the wall in the workshop... gives me some helpful access when I need it!
