Notepad icon Notepad — Notepad for ARC: store project notes and connection details in a themed window Try it →
Interacting With The JD Robot Via Flashcards And/Or Objects
Would anyone have suggestions on how best way to go about interacting with the JD robot via flashcards and/or objects? The aim would be for the user to give some sort of meaningful visual response that JD can interpret and process.
QR codes are nice but they can be quite large particularly if the robot is further away. The only way I can think of keeping the codes small while maintaining the distance is to use a higher resolution camera but I'm unaware of any such cameras that are also compatible with the EZ-B v4. Glyphs also work but I think there are only 4 of them. If someone knows of a way to add more, that'd be great. Color detection can be noisy especially when the background colors also interfere. Object recognition is quite tedious and inconsistent as the object often needs to be angled and oriented a certain way to be detected. Providing ARC with a set of training images would be great but I don't know of any ways to do this or if it's even possible.
Each have their pros and cons but I'm keen to hear what your thoughts are. Are there methods I haven't thought of or better ways to go about detecting responses?
JD Humanoid by EZ-Robot
Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts.
Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots.
Create customizable QR codes for ARC, display/scan via Camera Control, trigger scripts on recognition and save decoded text to variables.
Camera Device by Synthiam
Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts
#1   — Edited
Use the object training. If you’re having challenges with angles and such for recognition, the machine learning training isn’t being performed correctly. Machine learning of all types requires human training to teach the machine. The cards you use will have to be taught at variety of angles. This means slightly angling the object as its being trained.
You will I’ll find that like anything, practice will overcome the challenges you face:)
Lastly, you have already discovered "programming with pictures" because I see the control selected in your question. That’s a proof of concept which demonstrates your question. However, the challenge with that control is the images are too similar for direction when rotated. A more reliable implementation of that control would be to use different cue cards for motion that have a higher degree of visual differences.
heres the link to programming with pictures: https://synthiam.com/Software/Manual/Programming-with-Pictures-16024
ill publish the source code tonight when my plane lands and anyone can modify the code to use better images
ps, thank you for selecting relevant skill controls to your question. It really helps keep things organized:)
Thanks for this. I guess I'll have to train myself to train the robotxD
Using cue cards like the programming with pictures plugin is basically what I'm going for. I'll keep note to use visually different cards for better results.
Thank you for the link and yes please, the source code would be awesome.
You're welcome, I'm glad it helped:)
