Translate icon Translate — Translate text via Microsoft Translator (auto-detect); EZ-B plugin stores translated and detected language variables. Requires Azure key. Try it →
This can all be done through scripts or through external applications. EZ-AI is an external application that can do all of these things. It communicates with ARC. It is a much more complicated process.
You could also use the camera component in ARC, The voice recognition piece in ARC and the pandorabot component in ARC. This is the first thing I would try. If it doesn't meet your needs, you can look to external applications that communicate with ARC.
The script component in ARC is very powerful. You would be able to tie actions to what happens inside of these components, but I would first start with understanding these components. Each of these components has a ? button on it. Use this button for instructions for that control. It will help you understand the control and how to use it.
hi D Cochran...
the ARC can combine with other robot part, bioloid? or only for ez-robot part? how to make the robot tall 60cm, with the ezrobot? can interactive talk, walk, recognition face and voice. i really need more info. thanks
I am doing this with a 3 foot tall upper body on an Inmoov robot. Size doesn't matter as long as you have the power to drive the motors you are using. If you were going to drive 24V wheelchair motors, you would drive a H-Bridge of some sort from the EZ-B with the power to the motors coming from the H-Bridge for example.
The EZ-B can be used with custom robot builds. ARC drives the EZ-B.
Look at this thread to see a custom robot build with ARC and multiple EZ-B's
https://synthiam.com/Community/Questions/7398
Take a look at this thread to see some sample scripts that drive other robots.
https://synthiam.com/Community/Questions/7220
The EZ-B and ARC aren't just for the revolution robots. It is the most powerful robot controller on the planet with the easiest to use interface for programming.
Master D, thanks for concern to help me....
before i know ez-robot i hv an idea to buy bioloid premium, do you think can combine with the head from ez-robot, so can interactive respond vocally to motion, glyphs, faces. or can not be combine, only just one product from ez-robot with Jd n need to add more part to build like alan robot? please guide more,
thanks
The head won't be able to be attached directly. You will have to do some modification to it.
EZ-Robot works with most of the arduino sensors. Digital and analog sensors you will be fine with. Serial should also be fine. I2c is a more complicated interface.
You simply build and fabricate what you want to build. Parts may need to be modified but that makes it your own.
hi Master D...
im sorry, its new world for me... about robot things. can you be more specific ... what mean by I2c? yes i think can be use with arduino sensors. so, did the head with complete cam for recognize face and voice can be separate part? as part i need to combine with the bioloid gp premium? or can not?
if i buy JD humanoid, how to make it tall 60cm? need to buy 2 set or like what? how you build alan robot? but not kind of face as human, cz too scary for me...
please guide. thanks
