Audio File Out EZB icon Audio File Out EZB — Stream MP3 or WAV files from your PC to the primary EZ-B speaker for robot audio playback, alerts, music, and voice clips. Try it →
Interface Ez-B To A Trossen Robotics Hr-Os1 Biped Robot
My HR-OS1 HR-OS1 robot (Oscar) is connected to my laptop through a Windows 'Putty terminal' via WiFi. It has it's own IP address.
The operating programs are open sourced C++, the platform is Linux. The controller is an Intel Edison interfaced to an Arbotix-Pro sub controller that drives the AX-12 Dynamical servos. There is a PS3 controller that uses Bluetooth to send commands.
I am not very proficient in C++ or Linux but, with help, I stumble along.
Is there a way to connect EZ-B4 to the Intel Edison through WiFi?
I suppose I could connect via a Bluetooth-to-UART and utilize the PS3 controller commands but that would be very limiting.
A USB to UART connection might work but the Edison has very limited USB connections and to date, there is no supporting code for that.
Thanks, Alan. I have installed the plug in, reviewed it's documentation. I have also created a Auto Position script with 20 servos positioned and ready to number.
DJ,
I can not drive an AX-12A servo with the Dynamixel plugin. I have a single AX-12 servo with the ID = 5; TX connected to D5 of the EZ-B4. I am supplying 12V to the AX12s and 7.4V to the EZ-B.
I set the Dynamixel script to Type Protocol_1. When I tried to Change ID I set original to V5 and the New ID to V5. I hit Execute, was asked if I was sure, I said hit Yes then was told "Done". Of course nothing really happened because the original ID is not V5 but AZ-5.
My project is posted on the Cloud as "EZ Oscar 01-04-16".
I have glanced at the various scripts and programs in the Dynamical.zip unzipped folder. I saw no initialization of UART . If I need to initialize the UART, what bd rate should be used? (I could have overlooked this because I went through them fairly fast.)
Are there other details that I am overlooking?
Thanks.
Never mind! I initialized UART 1 to 115200 and now servo 5 works.
Now to hooking up the full 20 servo chain.
Thanks.
Ah - the dynamixel servos are 1,000,000 baud by default. I can add a selection to enter your own baud rate for the servos if they are different.
Did you change that baud rate, or is that how they came from trossen? trossen might have changed the baud rate because 1,000,000 causes flaky issues with unreliable data transmission. I can see why they would change it - specifically since 115,200 is still very fast for sending servo positioning. Consider the EZ-B v3 was only 9600:D
I think the default rate for dynamixel servos from Trossen is 1,000,000 and I was going to work my up from 115,200 if that had not worked. I'll see how things go when I start building the complete servo chain.
Is there a way to read data from the servos? I would like to build an 'input pose' array by manually posting the robot, then read those positions into the array. When completed, I would write the positions into an 'action array' and put that data into the Auto Positioner.
Do you think that would work?
Thanks for the great plugin.
I haven't had time to work on a read function for the plugin. I did email robotis and gave them the source code if they wanted to implement a plugin - but they have yet to reply. If you know anyone interested at creating a robotis plugin, my plugin is open-source. So feel free to build off my example source code.
#15
Dj, I'm having the same problem. I wish now I would invested in DJ.
