Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
Interfacing With Roboclaw Controllers
I am using a RoboClaw 2x7A DC motor controller.  It has a .dll file containing functions to access the controller. My question is, how can I interface the ARC software with the RoboClaw .dll library? I see that there is a tutorials for creating a new .dll, but I just need to be able to access an existing one.
#1   — Edited
You have 3 options.
  1. make an ARC control. That might be out of your skillset range, but here's the info just in case. Always fun to learn:) :https://synthiam.com/GettingStarted/Behavior-Control
  2. RC Control. Page 50 of the user manual for your product explains how to simply connect the motor controller as a servo. That means you use the existing modified servo movement panel. Here's the manual for your controller: https://downloads.ionmc.com/docs/roboclaw_user_manual.pdf
  3. Serial mode. Page 55 of the above manual explains the communication protocol for using Serial to an EZ-B. The serial would require you to create some scripting in the custom movement panel
Out of those 3 options, i'd choose #2
