EZ-SLAM icon EZ-SLAM — Creates a map in a global variable; proof-of-concept SLAM visualizer (very experimental). Try it →
Spain
Interfaz ARC Mbile
Interfaz ARC Mbile
Hi, From the mobile application I try to make my robot speak in Blockly with the SayEZB block but I get the error that you see in the image Does anyone know how to fix it or what is happening, it is with a JD Humanoid robot? Thanks
JD Humanoid by EZ-Robot
Example ARC skill demonstrating converting, compressing and streaming MP3/WAV to an EZ-B speaker, with play/stop commands and TTS examples.
i believe the speech in mobil app doesn come out the robot but out the your tablet.
Make sure the path is correct to your sound file.
Yes the speech should work ,make sure the google voice is updated on your mobile device, My mobile phone has a cool modified British/Cylon type voice that I also use on Google home app for Google mini speaker. Then that same voice is coming out of my robots when using Mobile Synthiam Arc.
