Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
I am not exactly sure what you want to do...Is you computer wifi or are you connected to the router with network cable?
wifi to router.normal it chows icon from wifi connected in the taskbar below right.no cable
I am still not sure what you need... Maybe someone else can chime in and help... sorry dude...
maybe this pic helps.
Do you see the button with the arrow up in the taskbar (lower right beside the little flag)?... This is where more taskbar icons are... It should be in there, click on the icon with the arrow... If it is, see if you can drag the wifi icon to the taskbar....
Right click your taskbar and select properties... In there under the Taskbar tab you can choose which icons to show (where it says taskbar buttons)... I think you need to choose, "never combine"... But try different settings a see what happens in the taskbar...
#15
You can't change the wifi icon, it changes by itself depending on the status of the adaptor.
You have the wifi icon it's just set to hide itself. Change it to show all the time by clicking customise when you click the arrow to bring up the group of tasktray icons.
Fix whatever the error is and the red/yellow star will be removed from the icon and it should show the icon you are trying to get.
What is the error that is reported when you hover the icon?
no errors has bin given.i can chow it up for all the time to see.but its the wrong icon.
