I noticed that on the Talk servo 2, the "invert direction" does not work, it just stops the servo dead.
Has anyone noticed this?
Figures it out, invert direction has to be less than 90.
EzAng
Brushless Motor Movement Panel
— Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement.
EzAng
solved it, hast to be less than 90
Actually you discovered a bug - I just fixed it for ya cause i was curious about it. I'm going to push an update for Early Access because it's a minor easy fix.
I thought so,
I figured a work around - under 90
Great, thanks Dj, all my best
Here you go: https://synthiam.com/Products/ARC/Releases/ARC-2021-12-27-00-Early-Access-Runtime-20931
Thanks again, I downloaded it already
My ARC says 2021.12.27.00
Great service as usual DJ! Thanks!!
