Connection Diagnostic icon Connection Diagnostic — Diagnose EZ-B Wi-Fi connection issues with verbose EZ-B communication logging, ping tests, log export and diagnostic reports for Synthiam support. Try it →
IoTiny over WIFI disconnects immediately after connection
Iotiny Over WIFI Disconnects Immediately After Connection
Hello! I have the following setup: Port 0 : IoTiny configured in AP Mode as master Port 1: Arduino via USB Port 2: IoTiny configured in Client Mode connected to Mater IoTiny
In windows I can successfully connect to the AP Mode IoTiny. In ARC I can successfully connect to all three ports. I can send 1 servo command via the IoTinys, but then both automatically disconnect immediately after.
  • I have tried changing the IP addresses.
  • I have lowered the battery monitor setpoints to 4 V. The Tiny's are running off a power supply at 5V.
Is there something else I should try?
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
#33   — Edited
Outstanding!! Nice work guys!! This make me feel good.
What did you end up buying that replaced the old barrel plug?
#35
Nice, Jer nailed it!! His skills and knowledge in very impressive. We re very fortunate to have him hanging around here and willing to help.
#36
Thank you very much for the kind words, Dave! We are fortunate to have you here too!
#38
Nice find Nomad. They will only handle 3 amps but very nice for small demand projects. Thanks!
