Auto Position Movement Panel (Gait) icon Auto Position Movement Panel (Gait) — Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control Try it →
Here is what I do...
I use a smartphone to connect to the EZ-B V4's wifi. I then open the browser on the smartphone and go to https://192.168.1.1. I then change the EZ-B V4 to be in client mode. This will assign the ip address a non-conflicting ip address from your router using DHCP. I then join my smartphone back to my network.
This will allow you to access the EZ-B V4 from any device on your network.
