Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
England
Ipad Air Connecting To Ez-Bv4
Until two days ago had no problems connecting IPad Air to Ez-Bv4 in either mode AP or Client. Now all goes well until you hit the connect button and the controller beeps and the red light comes on. No servo's are connected and the Lipo is fully charged. I have two Ez-Bv4's and cannot get either to connect. Up till now it was a doddle but am I overlooking something ?
If the red light comes on, that means there's a communication error with an i2c device. If you have a JD, that means his eyes do not have a good connection. Here's more information in the FAQ: https://synthiam.com/Tutorials/FAQ.aspx#5
Also here is specific Red LED FAQ: https://synthiam.com/Tutorials/FAQ.aspx#11
Based on your diagnostic info, it appears that you have a JD robot, or are at least opening the JD project. If you indeed have a JD robot, then verify the RGB eyes are connected and powering on correctly.
If you do not have a JD robot, ensure you have a set of RGB Eyes connected to the EZ-B. If you do not have a set of RGB Eyes, remove the RGB Animator Control from the project.
England
Well done DJ,problem solved.RGB animator closed and no problems connecting. A bit puzzled though because nothing had changed to my knowledge. Great work,great product.
