Continuous Servo Movement Panel icon Continuous Servo Movement Panel — Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options. Try it →
Iphone 6 And Ipad 2
Iphone 6 And Ipad 2
I have the Galapagos bot and I have loaded the iPhone app, when I use the iPhone app everything connects to the robot but the control all go crazy and the diamond arrow controller does not work. When I use the iPad 2 with iOS 7 the app works better. The bot will walk but only if I go to the controller tab. All the tabs respond correctly. But on the main interface of the app the diamond arrow controller does not work. Only the red stop button works. I do not have a windows PC to do any programming on. I am all apple based. I do have a 3 year old PC laptop running windows 7 but the ARC software will not work on there. So I am mostly counting on the mobile apps. Do the mobile apps need to be configured on a PC first before they will control the bot. I figured the ready made apps would work right away without configuring. Also can you steer me to a tutorial on connecting the wii remote for controlling. Any help would be great
Wow! The bot in the video had such fluid leg movements. Makes me want to get one. But I have enough to play with with JD yet. However, I think I'll download the project on that robot and study the AutoPosition settings for it to see how it is done. Assuming those leg moves came from that project.
WBS00001
its original from dj
@Dodgerrrr.
Hey there.
Not that this will directly solve the iOS app issue you posted about (looks like DJ has you covered there), but I'm curious to why ARC PC won't work on your laptop. The minimum requirements for running the PC version of ARC are Window 7 or later, at least 2GB RAM, have at least 50mb of disc space available, and have an Intel Pentium or AMD 64 or 32 Bit 1 GHz CPU installed. I have a 4 year old Windows 7 laptop and a 2GB RAM Windows 8 tablet that both run ARC really well with no issues. You shouldn't have any problems running it.
I mention it because as your enjoying your new Galapagos bot, you will REALLY enjoy ARC PC. It's a fantastic, easy to use and very powerful peace of software, and I'm sure you will love it.
BTW, welcome to the forum.:)
i updated the iphone and all apps.and indeed some dont work,like forwart/backwart/left&right.
Hi Steve G Thanks for your imput. I will try to load again into my pc and show you a snapshot of the error message I get. Maybe you can give me a tip on how to get it running in my pc. I'm a Mac person and pc always gives me problems. Thanks Dave
Just a guess without seeing the error message, but it is most likely that you don't have the proper dotnet framework installed. You need dotnet 4.5 (downloadable from Microsoft)
Great I will try downloading that. Thanks. If I could get that running it would help a great deal. Thank you
#16
Thanks DJ, The iPhone and iPad app now both work fine. One thing though, when I push strafe nothing happens what am I doing wrong with the strafe buttons?
