The Better Navigator icon The Better Navigator — Hector SLAM navigation with NMS pose and obstacle data for room mapping, waypoints, and autonomous obstacle-avoiding routes. Try it →
Ir Autonomous Home Base
have 2 ir recievers from my wall-e project. Looking to make a cheap/nearly free home base ir reciever.
Could they be hacked up to work with the ez-b and my laptop(and extention cables from my laptop)?
Could anyone point me towards a post similar to this?
#17
YOU would need 2 of then at least at $25 each including shipping
#18
couldnt we tweak the coding in it to acomodate serial instead of i2c
#19
YES,but cheapest way way to go is ,just use the IR transceiver you first posted hook up to digital port and read the PWM value only cost you about $0,both designs will need a IR TRANSCEIVER TSAL7200 AT $.80 EACH ,so your total cost would be about $2.00
#20
TRY to understand serial is for communcation ,not for beacon used for Ir Autonomous Home Base
#21
yea just wrapping my head around things. So read pwm values from the receiver. and just give the tranciever power?(doesnt require serial connection)
#24
going to need to drive the transceiver with a pwm value and i will need a transistor
here is info on SET PWM for transceiver and info on GET PWM on receiver
EZ b script manual
now on PWM value for transceiver i need to test the value on the POLOLU IR beacon beacon board
if you look at the circuit you can see the simple drive circuit that is needed
