Tutorial icon Tutorial — Tutorial slide plugin for ARC: create, format and embed text and images per .ezb project; navigate/update slides via ControlCommand; auto-resize images Try it →
Irbot Create Issues
Hi, i'm trying to get my Irobot Create working and my connection seems to be fine, it say connected buy when I try to make it go forward nothing happens, I've check my cord, it did actually work 1 time then I picked it up and I can't get it to work, any ideas.
sojc_98
Press the CONFIG button and ensure you have the proper settings for your version. Check if your version uses 115,200 baud and if it is a model using the old protocol.
nothing, it looks like things are getting to the controller ,but it stops? anyway to send a reset command from your software?
sojc
Check the manual for your version of the irobot create. Then press the CONFIG button in the iRobot Roomba Movement Panel in ARC. Select the baud rate and version.
To re-init the roomba, press the INIT button on the movement panel.
still nothing, i'm at a lose what it could be, i've double checked everything, and the irobot create is new..how can I do some checking to the board to make sure it's not the board?
You can connect a servo to port D0 and see if it moves. If it does, then D0 is working. If you accidently shorted D0 out, it could damage the port.
I'd double check your wiring to ensure it's all golden:)
yup, D0 doesn't work but D1 work with the servo? so now what, How did that happen, I never connected them backwards or anything else.....
confused
Do you have a volt meter?
If so, plug the cable into your roomba and check the voltage on the GND and Signal wire (Black and White) out of your roomba that connects to the EZ-B. What voltage do you read?
k, thanks for all your help, i'll get one tomorrow and let you know.
sojc
