Graphy icon Graphy — Plot live data with ControlCommand scripts: multi-series charts, many chart types, legend toggle, add/remove series, export graph data to CSV Try it →
Irobot 530 Quick Advice
Hi guys.
I am currently looking at a Roomba IRobot 530 on a popular auction site I want to get. I don't wish to appear rude but I need some quick advice before I place a bid, as the clock is ticking. eek
Does the 530 have a comms port to connect the EZ-B4?
Is the 530 compatible with the EZ-B4?
I've never had a robot vac so it's all new to me. I know DJ does reference the iRobot but there's no mention on models.
Cheers.:)
#25
This will turn the brushes on and off via software...
#uses pin 5 (UART port 1)
uartWrite(0,1,138,13) #on
uartWrite(0,1,138,0) #off
#26
I uploaded a sample project to control your Roomba 530... Look in the cloud under sharing in the drop down list for Roomba 500 custom movement panel2
Don't forget to run the init script before first...
#27
Thanks for that Richard. I did have a quick glance at your sample project the other day. Ordering new EZ-B tomorrow so I will have a good play around with this set up when it arrives.:)
#28
I have updated it just now.... have another look if you want....
#29
Thanks. I'll take a look now.
#30
Hey guys.
I need a little advice. I've just ordered a little 5v inferred remote relay to power On/Off the EZ-B but I'm wondering about powering the relay itself. Could I use the 5v regulator from the shop and use the Ground and Possitive pins from the Roomba 530's comm port to connect to the relays input?
Of would something like a Buck Converter like this be a better option?
Thanks.
#31
The power pins available via the Roomba 7 pin mini din will only support a power drain of 250 ma. If that is exceeded then the internal poly-fuse will trip. The fuse will auto reset once the overload is removed. You might want to use another voltage source and a 5 volt regulator.
#32
@RobotDoc.
Damn, that's a shame. I suppose I can hook it up to the EZ-B's battery but I figured as the 530 is always on when charging, this would be ideal for the R/C relay and could be continually on as well. Oh well. Thanks for the heads up Doc.;)
