ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
Just play with it, learn the commands (I'd highly suggest reading the EZ-Script manual a few times to get to know what commands there are and what they do) and just try different things.
If you can think logically you just need to find the correct syntax for the commands, it's very easy to use.
You can play with it before you get the EZ-B too.
I agree @Rich.....I played with and created a huge file with all kinds of coding and scripts waiting for my EZ B to arrive. This file was all less any servo/sensors scripts of course , but at least you get to play and teach the VR stuff!
Good news! wall-e is taking shape so he may be JARVIS's body!
Wall-VIS? JARL-e?
I don't know. which one is better?
AWWWWW COME ON!
You could still play with the servo and sensor controls even without the EZ-B.
Servos, digital, movement etc. just add the servo/digital/movement controls and watch the script change them (ignoring the debug window throwing errors constantly) Sensors, you can use random numbers to emulate sensors, check my PingRoam script for the test mode which I left in.
Also, I'll probably be moving my Jarvis over to ARC in the near future, which will be mainly scripts and VR since control of most things has been done through other means. I'll be sharing all of the scripts so it should help figure out how to do a lot of the fun things like news, weather etc.
It'll also include a cool little lighting control idea I have had for my stair case for a while:) Watch this space (well, watch the showcase).
@technopro,
And, don't forget to look at the examples in the cloud.
#15
Is there a way I could have ARC in the background and then tell it what to type in the selected box?
#16
How do you mean? What selected box?
