Ohmnilabs Standalone icon Ohmnilabs Standalone — Connects Ohmnilabs Telepresence robot's UP Board COM to ARC, enabling drive and servo control (neck V0) and integration with ARC cameras. Try it →
Is It Possible To Connect To Robot And Internet At Same Time
Hi,
I am running tutorials and trying to program my robot at the same time - I keep having to switch my WiFi from my ISP network to the robot and back again. I could use my phone to stream the tutorials but does anyone know a way to connect to both the robot and the internet from a laptop? I'm guessing you might need some third party network adapter.
Robot: JD Humanoid OS: Windows 10 Home
Thanks
Phil
Twitter
Hi Jon,
I am not sure this belongs in this thread. You may want to start a new one.
It sounds like the battery is charged based on your description. Is it new or second hand. Take the cover off JD and make sure he is connected internally to the battery. Did you check the fuse? If you have a multimeter you can also check the battery for power.
Jon, I believe the terminology is misused in the post. You’re inquiring about the charger, not the batteries. The tutorial where you saw the charger that caused you to believe is different actually had information for your charger as well. You will have to scroll the webpage down to find old charger documentation. There will be a scroll bar on the right side of your browser window. By pointing the mouse cursor at the scroll bar and clicking, you will be able to scroll lower through the text. Find the version of your charger. Here a direct link: https://synthiam.com/Tutorials/Lesson/26?courseId=1
