If you have a wheel chair that is built with a brake instead of just forward,backward lines, can you make it into a base?
Thanks,
:D
Openai Dall-E Image
— Generate or edit images with OpenAI GPT Image from text or camera frames, with save and programmatic control commands.
Thanks,
:D
Most people open up the motors and remove the breaks. You can just apply power to the break line to turn them off (I would recommend a tip transistor to a relay rather than wasting an Hbridge for a simple on/off) but it will use up a lot of battery power just to keep the breaks open. On the other hand, makes a nice failsafe for a device with enough power to hurt you and even kill a pet or child that gets in the way.
