Ultrasonic Radar icon Ultrasonic Radar — Ultrasonic on a servo sweeps 180°; radar shows distances and obstacles, integrates with movement panels for automatic avoidance, scriptable GetPing Try it →
Is There A Better Wireless Camera For ARC?
We have two issues with the existing camera that came in the kit.
  1. It drops the link and can't get it back for hours or days.
  2. Ever since the new SW builds, where we lost resolution control, it is inadequate to accomplish the tasks that we designed the bot to do.
We are now at the end of our time and we have nothing to demonstrate because it either does not work at all or it works but can't find the glyphs from the desired range.
All suggestions are welcome.
Thanks again
why do you need to remove the plastic shell from the usb dongle DJ, it makes the board week and can easy get damage or shorted
i re-look at the video and i see why the cover is removed the button on the side doesnt have a hole for it,(thats kinda dumb) i hope that the cover is replaced,its not on the video,i would drill a hole on the side for that switch,maynbe hole for the sending and receiving leds ?
Awesome. I did not know about that pairing button inside the dongle. I will try it tonight!
Thanks again DJ
@Troop, you only need to pair if the camera doesn't work. It only requires pairing once per lifetime. The instructions about how to turn it On and Off are what i'm directing you to:) .. if your camera works, you don't need to re-pair it
@robotmaker, i do not understand your question.
not a question its a idea,instead of opening up the dongle each time,make a hole for the paring switch Rest of the comments was before i saw the video
i had problems with my bluetooth mouse and i tried the paring button ,it has the button on the bottom and found out that sometimes my bluetooth will work and sometimes it doesnt and tried paring it no fix
so like you said i might have a RFI problem or noise,since i have bluetooth running,WIFI running ,X10 thats both RF and IR and ac current signal all over my house,most likely it X10 NOISE since every outlet,every light ,pool,juccuzi ,A/C unit all use X10 SYSTEM plus my alarm systems uses X10
We are very familiar with how it should be turned on and off. I have held that button from seconds to many minutes. It does not turn off.
did DJ's idea about the paring button help ? seems like a faulty camera
#15
Hi robotmaker,
Thanks for asking. No, it did not restore the link, however my LEDs never looked the same as the ones in the video. And of course, I tried it many times. It is a good trick to know regardless. That DJ sure has a lot of tricks up his sleeves.
I am very willing to admit that the camera/dongle does not work. My fault. My question is: is there a camera that I can buy that will replace it and give me the performance that I used to have with this camera, several SW builds ago?
Thanks again
#16
@troop. If you have a 2.4 ghz wifi router nearby try configuring it to operate on a different channel. Perhaps your router is flooding the frequency the ez cam is also running on. I have not had the problem but my netgear router is set to channel hop for best connection integrity.
