Tutorial icon Tutorial — Tutorial slide plugin for ARC: create, format and embed text and images per .ezb project; navigate/update slides via ControlCommand; auto-resize images Try it →
Is There A Way To Run Autorun Script On A Mobile Interface Connection?
I know how to run a "Connection Established Cmd." in the Connection Control in ARC for Windows, but can't find the equivalent for the Mobile Interface.
Any ideas on how to autorun a script on conjnection with Mobile device?
Regards, Frank
its the same. what ever you have in the connection established for the connection control will run when mobile interface connects to ez-b as well
its the same
Visit the help manual page for the mobile interface control to see supported controls: https://synthiam.com/Support?id=196
You will see "Connection" as a supported control.
@DJ Thanks... I had a non mobile supported command in my On Connect script
Regards, Frank
Anytime man:)
You can see if there's any mobile errors in the View log on the main screen of the mobile app
