is it possible to use 3 lotiny to 1 speaker ?
— Edited
5 Participants
Remote Mouse
— Scriptable Remote Mouse for ARC: control PC cursor and ARC window via ControlCommand, using voice, camera or I/O inputs; shows cursor coordinates.
I wouldn’t recommend that. The simplest way is to do this...
great dj but thats chinese for me.i can make this ?
each lotiny gets one wire?
these are the ones i have.
Patrick, you have got it as long as the commons are all tied together in some way.
Here is a handy site for resistor color code calculation: https://www.resistor-calculator.com/
A 4.7K resistor has the color bands Yellow, Purple, Red and a gold band for 5% tolerance.
If connecting 3 EZ-B's instead of 2 would the resisted value still be 4.7k? I suspect that is fine. I built a passive mixer to connect several devices in my car, and the instructions were to use 10k resistors for three inputs, but that was line level, not to a speaker.
Patrick, the volume will be lower than individual speakers. Shouldn't be bad, but you should be aware.
justin
the commons are ground ?and 3 red needs the resistor. is there a direction for the resistor to solder? these wil do?
alan
thanks for telling about the volume.i am using 3 lotiny's.
Resistors do not have a direction. Commons are also known as ground.
great thanks justin.
