Rubik's Cube Solving Robot icon Rubik's Cube Solving Robot — Control a custom ARC robot to manipulate and solve a Rubik's Cube using calibrated arms and grippers; integrates with Thingiverse build. Try it →
Is there a way to have a movement panel with more than 2 continuous servos?
Is There A Way To Have A Movement Panel With More Than 2 Continuous Servos?
I recently built a robot that has 4 wheels to it. I quickly realized that was a bad idea because from what I've seen, there is no way to control more than 2 wheels with a movement panel. If I am wrong, please tell me. If I am right, please notify me. Is there a way to control 4 servos through a single movement panel?
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
You didn't specify what kind of motors you're using. But no matter what you are using, connect the motors. Or, if you feel that you need to use I/O unnecessarily, you can use the custom movement panel. It makes sense to me to connect the hbridge or servos on the same i/o.
You say motors but also servos? If it is servos your talking about, I would think that a "Y" servo cable would work? Although I have never tried it.
#3   — Edited
you can AD multiple servo's and use one control . if you use the "Y" SPLITTER  they only turn in desame direction or you have to check , the box for invert . you can do very safe some testing with the controlls . see what it does .
Same with hbridge - you can connect multiple hbridge to the same i/o:)
@DJ Sures I am using 4 HDD continuous rotation servos from EZ-Robot.
winterrrrrr
am gessing 4 pwm then .
