It may be me. But I cannot create a shortcut
I tried on two computers, but it did not work. It was a GREAT idea to have.
Thanks for all of your hard work.
Mel
MMA7455 Accelerometer
— I2C accelerometer for EZ-B robots, supplies IMU/acceleration data over the I2C interface.
Mel
One other person is having an issue. Not sure what causes it - because generation of the LNK fie is a generic windows function.
It creates an Exception Error. Maybe I can find another way to do it. If it is a windows problem.
Here is some more info if it helps.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.IO.FileNotFoundException: Could not load file or assembly 'Interop.IWshRuntimeLibrary, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. File name: 'Interop.IWshRuntimeLibrary, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' at EZ_Load_Creator.FormMain. (Object , EventArgs ) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
EZ-Builder Assembly Version: 2012.8.19.0 Win32 Version: 2012.08.19.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot/ARC.20Installer/ARC.exe
System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
EZ_B Assembly Version: 2012.8.19.0 Win32 Version: 2012.08.19.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot/ARC.20Installer/EZ_B.DLL
System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1109 (lh_tools_devdiv_wpf.071009-1109) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Speech/3.0.0.0__31bf3856ad364e35/System.Speech.dll
Microsoft.DirectX.DirectInput Assembly Version: 1.0.2902.0 Win32 Version: 5.04.00.2904 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot/ARC.20Installer/Microsoft.DirectX.DirectInput.DLL
WindowsBase Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.5011 built by: Win7SP1 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
Microsoft.DirectX Assembly Version: 1.0.2902.0 Win32 Version: 5.04.00.2904 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot/ARC.20Installer/Microsoft.DirectX.DLL
ugrxyfne Assembly Version: 2012.8.19.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
It seems that the assembly binding is turned off. Don't know why. I tried to set the fusion to a value of 1, but could not find the key.
I can't seem to get it to work either.
It craps out with an error and then locks open the .EZB file so I have to re-name and save my file as something else.
OK, Lumpy, here is what I did to make it work.
I created an autoconnect script that called init.
then I right clicked and sent the shortcut to the desktop.
then, I dragged the shortcut to the start bar.
then I dragged the shortcut to the Start-up folder.
Now, when i turn on the computer and EZB, the robot starts and initializes and waits for verbal commands.
Oh, i had to place connect Robot please and disconnect robot, please to the speech recognition script.
Look at the auto connect script under examples.
I finally have my basic finished robot and she works good. I just don't have a suitable place to operate her because I have no room in my apartment.
yeh!
:D
Do you have 32 or 64 bit windows?
Running 32 bit Windows here.
I'll do some screen captures tonight.
