Script Collection icon Script Collection — Manage and execute multiple scripts in a single Script Manager using ControlCommand(), with Control Details showing available commands. Try it →
JD Robot Occasionally Spasms When Closing ARC Without Disconnecting First
Sometimes, when closing ARC, JD's servos violently spasm and rush towards their limits. However, I noticed this doesn't happen when it's disconnected first before closing. I don't know how to replicate this problem nor do I know why it occurs. Has anyone else seen something similar to this before? Or have any suggestions on how to go about fixing this?
JD Humanoid by EZ-Robot
#1   — Edited
Never happened to me with the new HDD servos, but the only time I close ARC first is/would be by accident... So How to fix it? You already have your answer... Don't close ARC first... Instead the correct way is to disconnect first. Even turning JD off first is preferred...  Problem solved and less risk of damaging your robot...
Sounds more like a workaround than a solution. I'll try and replicate it every now and again to see if I can find a pattern but in the meantime I'll do that. Thanks for replying.
