Sabertooth Movement Panel icon Sabertooth Movement Panel — Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options. Try it →
Jd Battery Won't Hold
My JD robot will not hold a charge for more than 15 minutes. I am not sure if my charger is bad or my battery is bad. My other JD robot is also having trouble holding a charge with its charger. What is wrong with my battery?
