Robot Skill To Camera icon Robot Skill To Camera — Capture a robot skill's display and stream selected area as video to a configured camera device with FPS and live preview crop. Try it →
I can't get the JD camera to work:
Quote:
2/22/2016 3:00 PM - Camera Initialized: EZB://192.168.18.51 @ 640x480 2/22/2016 3:00 PM - EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 2/22/2016 3:00 PM - Camera Disabled
I've connect to another EZB4 and the result is the same, I run the telnet with ezb ip and port 24, it connects i drop a few chars but i got no response and the connection is still open.
Is anything more i can do to help troubleshoot the camera ?
Thanks
Does the LED flicker or come on?
Is the cable connected securely on both ends?
As well as making sure the cable connections are tight, give an extra push on the cable to make sure it is properly seated in the connector. The camera that came with my Six, I thought was bad because it stopped working after just a few minutes. Turns out to be one of the wires was not properly crimped in the JST connector. Error was the same when it was failing.
when i power the EZB the camera module blinks the blue led. No blink or other visual sign when i try to connect the camera via camera control.
I'll check the cable to see if the wires are ok
ok, i checked the cable's wires with a multi-meter, it seems good, the camera module (pcbs) are warm.
Anything else i should check?
what for me helped was turn the cable 180 degree,
It has two pcb's? Perhaps the camera is defective - if it's within warranty time frame, contact ez-robot support and include a link to this thread.:) We'll get you up and running!
Thanks DJ
